Author Topic: changed engine over but damn thing wont run- help  (Read 6894 times)
Offline SarahD
« on: 06 April 2006, 13:33 »
fitted the 1.8 back in a few days ago  got everything wired up ( at least i think its all in properly) the car will turn over, and sparking but wont "run" cant see anything visibly wrong with it, just not sure what else it could be. the timings ok,its getting fuel and a spark,  weve checked that, but dunno where else to look now, can anyone help or gimme anything i should check, or if anyones local to me who can come and have a look itd be mucho appreciated
thanks Sarah
Offline Organisys
  • Old and Slow...
Re: changed engine over but damn thing wont run- help
« Reply #1 on: 06 April 2006, 13:34 »
digifant or K-Jet ?
Veedubgt18v
« Reply #2 on: 06 April 2006, 13:35 »
check your timing.
Offline SarahD
« Reply #3 on: 06 April 2006, 13:43 »
timings spot on, and its a 1.8 8v so whatever that is, i dont really know a lot about the engine codes lol
Judderi
« Reply #4 on: 06 April 2006, 14:58 »
So have you replaced your mk3 2.0 8v for the origional 1.8 8v engine? K-jet is the mechanical injection and has the braided wires on the air box. Digi the electronic type and has an electrical sensor on the intake hose. If its turning over really quick its usually a snapped timing belt or even worse, internal damage. Whats the history of the engine? Whats it from? Was it running before?
Offline SarahD
« Reply #5 on: 06 April 2006, 16:15 »
yes its been replaced for the original. its not turning over really quick, the timing belt is intact, im not that thick!!!!!! the engines from the car we bought and it was running before we took it out of the car
Offline jezza16v
« Reply #6 on: 06 April 2006, 17:16 »
The timing could be 180deg out, you would still get the spark near to TDC but it would be on the exhaust stroke rather than the compression stroke. The piston would still be at the top of the cylinder but the valves would be open rather than closed - this is a very common error.  :wink:
Offline SarahD
« Reply #7 on: 06 April 2006, 17:18 »
my fiance had a feeling it could be this cos we had to change the distributor cos the one on it was fooked, any way i can do it or tell if its wrong?
Offline jezza16v
« Reply #8 on: 06 April 2006, 18:19 »
Well this is how I would check:
Follow the No 1 cylinder plug lead back to the dizzy cap and make a note of which one it is.
Take the no 1 spark plug out (you could take them all out to make the engine easier to turn over) and turn the engine over by hand and watch for the No1 piston to come up to its highest point.
Take the oil filler cap off and I guess you should be able to see the No1 cylinder exhaust cam, if it is pointing down then your on the tdc exhaust stroke so turn the engine over by hand again 360 deg until the piston comes up to the top again and the cam is not pointing down. The piston is now tdc on the compression stroke.
Now take the dizzy cap off and see in which direction the rotor arm is pointing, if its not pointing in the direction of where the No 1 lead was and pointing in the opposite direction then the dizzy is 180deg out.  :smiley:  I expect someone may have a quicker way to do it??
Offline yellowgti
« Reply #9 on: 06 April 2006, 18:35 »
ok this may sound silly same happend when my gti engine was put in basically it was a earth lead to the gearbox but check them all ! u never know! :smiley:
"Some say he has a brain made out of fish and that he has no drivers licence at all, all we know is he's called The-Stig"
