Author Topic: track rod end removal  (Read 2581 times)
Offline Simpson
  • one day il learn
« on: 18 March 2006, 13:02 »
I am trying to change the hub on my 89 gti 8 valve, how do i ghet the track rod end bolt through it wont budge, i have removed the nut obviously, cheers  :smiley:
i must buy a new car!
Offline Bazzer
Re: track rod end removal
« Reply #1 on: 18 March 2006, 13:14 »
I remember snapping a set of mole grips on mine before someone suggested heating it up with a welding torch... Worked a treat....
Bazzer
Offline ...joe
« Reply #2 on: 18 March 2006, 14:33 »
get a copper hammer and beat the hell out of the hub. so on the part that houses the track rod end. it should pop out that way.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
« Reply #3 on: 18 March 2006, 18:43 »
Get one of these from Halfords, popped that b!tch off in 5 seconds  :cool:
Offline yorkie
« Reply #4 on: 18 March 2006, 21:11 »
A welding torch will also nicely cook the nylon bearing rendering it useless.
Does your car now wander all over the road??
Usually just put the nut back on enough to protect the thread, a few smart taps around the housing and one on the nut and it should pop out.
Offline AudiA8Quattro
« Reply #5 on: 18 March 2006, 23:52 »
Use the separator, DON'T hit it  :rolleyes:
Offline silkyballs
  • more tea vicker??
« Reply #6 on: 19 March 2006, 01:15 »
lol yeah kick its head in!!!lol i think i need theropy????lolusing tha tool for the job is the best policy as they are pretty cheap and the chances are you will need it again im sure!since rebuilding mine i have purchased many specilaist tools and beleive they do get used. :wink: :grin:
http://[img]
Offline Simpson
  • one day il learn
« Reply #7 on: 19 March 2006, 11:22 »
cheers all sorted i bought one of those tools from Chavfords, job done, saves wacking the thing, nice one,  :smiley:
Offline Diluxe
« Reply #8 on: 13 September 2006, 12:46 »
Hi guys want to change my Track rod end tomorrow, does the actual end just screw off?
cheers
1997 16V
« Reply #9 on: 13 September 2006, 12:49 »
It depends!
If you have PAS both sides screw off, if you don't from the factory only the driver side is threaded on, the passenger side is fixed so you'll need a complete track rod.  Though this doesn't mean it hasn't been done in the past so have a look!
The way it works is the end threads onto the track rod, then is locked in place with a locking nut.
