Author Topic: track rod end removal  (Read 2588 times)
Judderi
Re: track rod end removal
« Reply #10 on: 13 September 2006, 13:11 »
Ive always just belted mine. Works a treat no need for these fancy tools!
Offline Diluxe
« Reply #11 on: 13 September 2006, 16:18 »
oh i see, so if i need the full track rod for the passenger side , is it a big job to take apart? is there anything else i might aswell change if i got to do this?
cheers
1997 16V
Offline Diluxe
Re: track rod end removal- wheres the locking nut?
« Reply #12 on: 14 September 2006, 17:38 »
right i'm having problems removing my left side track rod, theres supposed to be alocking nut but i cant see it, can anyone point it out to me on this picture?
cheers
« Last Edit: 14 September 2006, 17:45 by Diluxe »
1997 16V
« Reply #13 on: 14 September 2006, 19:25 »
if ya look closely, the locking nut is the slightly different coloured bit to the left right up against the threads with a flat on it, the rod end has its own flats near the rounded end :)
Offline Diluxe
« Reply #14 on: 14 September 2006, 19:43 »
what the bit with the red arrow below?, i know my posts make me look like a bit of a numpty, but i think its always best to check  :grin:
i did think it was that but i couldnt see a way of geting anything on to it to loosen it, any suggestions? and once thats off is it just a matter of with drwaing the rod or do i need to twist it off...............
cheers
1997 16V
Offline Dizzie
  • Make friends with your fast
« Reply #15 on: 14 September 2006, 22:00 »
I've hit them off in the past. hitting the hub not the trackrod end!
I've also used the proper tool from time to time :D
Mk4 Golf 150PD
Offline Diluxe
« Reply #16 on: 14 September 2006, 22:22 »
dizzie, i think you jumped a stage there mate  :laugh:, so once i got this locking nut loose , i gotta smack the hub to seperate parts A and B in the picture
1997 16V
Offline m1xmag
« Reply #17 on: 14 September 2006, 22:48 »
Get one of these from Halfords, popped that b!tch off in 5 seconds  :cool:
ball joint separators - such a wonderful little tool :)
Oak Green Dubs owners register/forum - drop along and add yours to the list! CLICK HERE
Offline Diluxe
Re: track rod end removal - struggling
« Reply #18 on: 23 September 2006, 11:59 »
guys really struggling to undo the locking nut due to lack of space and cant get a tool on part B due to brake line , how on earth do you seperate the two parts??????????????????????????
1997 16V
« Reply #19 on: 23 September 2006, 17:51 »
try undoing the rack mounting UJs and slide it across a bit, might be able to get more clearance that way?
