Author Topic: How to remove front speakers.  (Read 2864 times)
Offline Ant
« on: 15 March 2006, 09:34 »
Sounds like a dumb question, but the screws that are holding my speaker on are quite tight, and I can't undo them as I can get a screwdriver on them as the windscreen's in the way.
If I use my ratchet set the extenion also makes it too big.
Anyone suggest an alternative cheap screwdiver/tool/solution, otherwise I'm going to get racthet that directly sockets onto my screwdriver bits (which is more money than I'd have liked to spend).
Offline HARDCOR3
Re: How to remove front speakers.
« Reply #1 on: 15 March 2006, 09:43 »
i know ppl like Mac tools and snap-on, do little thumb drivers, it's like a little ratchet end that screwdriver bits fit into, and just roll between your thumb and forefinger, they're well dinky, thats probably yer best bet, i have 1 of those and a little bit set with a propper mini ratchet for them, does the job perfick, failing that, just get your screwdriver bit, and clamp it from the side with a set of mole grips, job done....... :wink:
Offline GolfChick24
« Reply #2 on: 15 March 2006, 10:24 »
i used a right angled screwdriver meself that my dad borrowed from work.
Offline Ant
« Reply #3 on: 15 March 2006, 10:43 »
That's what I thought, I just can't find anywhere to get one from :(
I tried with mole grips, but couldn't get good enough leaverage + downwards force, and the dash got in the way. (I'm starting to think someone superglued them ;))
Offline shaggyjh
« Reply #4 on: 15 March 2006, 16:31 »
I have a tool i got from Halfrauds that looks like a bit of stainless steel that is bent right at one end and left at the other end ( good description eh!!  :embarassed:)
Works really well, i can't find it on their website but might be worth a look!
Offline Ant
« Reply #5 on: 15 March 2006, 17:52 »
I know what you mean, will have to go and have a good look, last time couldn't find it.
Offline ...joe
« Reply #6 on: 18 March 2006, 10:59 »
i used a ratchet spanner holding a screw driver bit, worked well.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Mr Blue
« Reply #7 on: 19 March 2006, 01:57 »
i bent an old screw driver using a blow torch.  :cool:
Offline Dizzie
  • Make friends with your fast
« Reply #8 on: 21 March 2006, 18:56 »
I used one of the removeable bits and turned it with a pair of pliers :D
Mk4 Golf 150PD
