Car audio
earthing point
Topic: earthing point (Read 3602 times)
dubslug
earthing point
10 March 2006, 11:55 »
where have u guys/gals with mk 2 earthed ur amps too if that makes sense, im toying with the idea of making my own holes etc, just wondered where u lot have ur amps earthed(amps fitted in boot)
1992 pearl grey 8v
GolfChick24
Here all the time
Re: earthing point
10 March 2006, 15:27 »
im using one of the bolts/nutts that holds the rear cluster in place, it touches the body of the car so scrapped paint off a bit n stuck em there
Dizzie
Forum addict
Make friends with your fast
Re: earthing point
10 March 2006, 20:24 »
or where the first aid kit usually bolts in. there are places around those locations on both sides.
Mk4 Golf 150PD
dubslug
Re: earthing point
11 March 2006, 11:09 »
cheers uys reason i ask is im stillgetting eninge interferance
got power cables down one side
rcas down other side with remote and speaker wires
earth is to the bolt on the lower half of the back seat yet im still getting whinning noises!!
help
1992 pearl grey 8v
1 Lp
GTI forum regular
Re: earthing point
11 March 2006, 11:16 »
so am i mate, and I've got mine same place as golfchick.... Im stripping mine all out in the week any way to finish off the install properly
VWs are like women, they need love care and attention
dubslug
Re: earthing point
11 March 2006, 16:10 »
some one has said earthing on the head unit??
could this cause this??
1992 pearl grey 8v
Dizzie
Forum addict
Re: earthing point
Reply #6 on:
11 March 2006, 20:21 »
yes possibley. it's down to the poor connection on the actual earth therefore the signal trys to find other routes to earth and goes down the wrong parts of the unit. Sometimes get so bad it burns out the earth tracks on your RCA connections.
Mk4 Golf 150PD
dubslug
Re: earthing point
Reply #7 on:
12 March 2006, 19:52 »
am i right in thinkin that the black wire on the mk loom is earth??, could i cut into this and use the earth block vw kindly put under the steering wheel??
1992 pearl grey 8v
j_s
Here all the time
Re: earthing point
Reply #8 on:
14 March 2006, 11:35 »
If it is the earth block then yeah you could use that
I drilled a hole in my wheel well and dremmeled the paint away and then stuck a big bolt with washers either side for my earth point. I'm using the standard earth and power cable for the headunit and at the moment use a Passat battery to chassis to engine earth cable + fixings which are about to be upgraded to 0g cable from chassis to battery and 2g from engine direct to battery as well, oh and I get no noise
Also check you have a good battery to chassis earth.
James
dubslug
Re: earthing point
Reply #9 on:
14 March 2006, 22:57 »
cheers js was looking at the earth that sits just behind the battery tray and its looking well corroded, not a good sign
1992 pearl grey 8v
Car audio
earthing point
