Car audio
mk4 interference aarrgghh
Topic: mk4 interference aarrgghh (Read 3068 times)
kingturbo
Guest
22 January 2006, 15:27 »
can anyone help me Ive got a Mk4 1.8t with a gamma headunit with a phatnoise and in between tracks i get an interference noise through my speakers that gets louder when i rev my engine i didn't bother me at first but now its really irritating has anyone else had this problem with a phatnoise or a Cd changer as they both run off the same cable and can anyone tell me how to make it stop thanks in advance
MrDan
GTI forum regular
Re: mk4 interference aarrgghh
22 January 2006, 22:33 »
Do you have any external amps?
i had a problem with interference from the engine onto the RCA feeds to a cheap splx amp...sounded like a cat in a blender!!
kingturbo
Guest
23 January 2006, 02:31 »
no running standard speakers of standard gamma headunit it sounds like a problem with the Cd changer lead to me just wondered if anyone else had any probs with theirs
Judderi
Guest
27 January 2006, 14:51 »
Usually you get this sort of issue when you run audio signal cables allongside power cables. How and where is the changer installed? Another reason can be a bad earth on the head unit. Also you can buy coil supressors that can help eliminate this kind of issue but they tend to be used on older motors.
kingturbo
Guest
06 February 2006, 23:17 »
its the factory cd changer lead ive never touched it if it was a bad earth would it do it on the radio as well?
Judderi
Guest
07 February 2006, 08:45 »
If you only get it when listening to cd's then id say its deffo an issue with the changers cables.
[han]
Graphic Designer for Haribo
Reply #6 on:
07 February 2006, 09:03 »
my mate had the same problem, and his cd changer then packed in!? it ws something to do with bad connection, but his cd changer was knacked anyway!
kingturbo
Guest
Reply #7 on:
07 February 2006, 18:11 »
do you know where the bad connection was?
GazB
Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Reply #8 on:
07 February 2006, 19:49 »
I would check all the connections anyway inc the earth, if not fit an in line noise suppresor
www.newportedition.com
Car audio
