Author Topic: Missing some readouts on MFA  (Read 4769 times)
Offline JezGTI
« on: 12 November 2003, 21:06 »
Distance driven, MPG and MPH appear as --- on my MFA.  The other readings seem fine.  Any ideas?
Blue MK2
Re:Missing some readouts on MFA
« Reply #1 on: 12 November 2003, 21:12 »
Same problem MPH and oil temp with mine.
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 12 November 2003, 21:26 »
try disconnecting the battery for a few mins. mine use to get stuck when I had a sh1te battery on there and doing that would reset it
Blue MK2
« Reply #3 on: 12 November 2003, 22:52 »
My MPH just stays on a random figure. Is this normal?
Offline Gambit
« Reply #4 on: 13 November 2003, 08:43 »
check the vaccum tube attached to the back of the clocks, if it aint attached then it cant read the MPG or the avg MPH
Offline JezGTI
« Reply #5 on: 14 November 2003, 00:34 »
What's the best way to get to that?
Offline Gambit
« Reply #6 on: 14 November 2003, 08:43 »
take the dash clocks out
Offline Dizzie
« Reply #7 on: 14 November 2003, 11:35 »
unless u have really small hands and arms that bend in several places the lot has to come out ;D
pull out your stereo, pull off all the switches and blanking plates, pull off the heater controls. There's 3 screws on the top (1 under the cage for your stereo and 2 above the dials) and 5 (I think) on the bottom. Once they're all out you can remove that cover. Then there's a screw either side of the dials to release them. reach round the back and unplug the speedo cable (this is a b!tch) then they should move around enough for you to reconnect the vacume hose
Offline Leejaydoob
« Reply #8 on: 14 November 2003, 11:37 »
do you not have to take off the steering wheel as well?
Blue MK2
« Reply #9 on: 14 November 2003, 11:44 »
Nope.  ;D
