Golf mk2
Missing some readouts on MFA
Topic: Missing some readouts on MFA (Read 4768 times)
Leejaydoob
GTI forum regular
Re:Missing some readouts on MFA
Reply #10 on:
14 November 2003, 11:49 »
i got to fit new speedo cable tomorrow
i thought wheel had to come off, one less job to do anyway
Ant
Here all the time
Reply #11 on:
14 November 2003, 12:17 »
Quote from: Blue MK2 on 12 November 2003, 21:12
Same problem MPH and oil temp with mine.
The oil temp is usually a disconnected wire. Look at the back of the engine compartment for a green wire with a black strip (as I recall) and slip it on to the connector (at least that solved my probs
Blue MK2
Guest
Reply #12 on:
14 November 2003, 13:58 »
Back of the engine compartment? Where are we looking mate?
Blue MK2
Guest
Reply #13 on:
14 November 2003, 13:59 »
just above my oil filter there is the green and black wire connected so im not sure where you mean?
Last Edit: 14 November 2003, 14:00 by Blue MK2
JezGTI
GTI forum regular
Reply #14 on:
25 November 2003, 16:52 »
OK, had the dash out and it seems like the vacuum hose was properly connected (although it wasn't that easy to see). So I still have mpg, miles and mph as ---. Any other ideas??
Gambit
Forum addict
Reply #15 on:
26 November 2003, 09:21 »
check the pipe then for leaks
JezGTI
GTI forum regular
Reply #16 on:
26 November 2003, 10:10 »
Thanks Gambit, do you know what route the vacuum tube takes in the engine bay? I thought this tube was only used to calculate the MPG, does it control the 'Miles' and 'Trip time' function on the MFA too?
JezGTI
GTI forum regular
Reply #17 on:
01 December 2003, 21:12 »
I have tried to check again to see if there is a leak on the vacuum pipe where it is connected to the MFA. The problem is can feel the tube with my fingers but don't know how to remove it from the MFA. Don't want to pull it too hard in case of damaging something. Anyone know how to disconnect this tube from the back of the MFA?
Any help with the previous message would be appreciated too.
Leejaydoob
GTI forum regular
Reply #18 on:
01 December 2003, 21:37 »
the tube just slips over a nipple on the back of mfa i think, but it may be a bit tight cos obviously it needs to stay on once its on
karmakanix
Reply #19 on:
06 December 2003, 16:27 »
mine reads the same and all hoses good. i think it is the gizmo on the gearbox that tells it engine speed.
Golf mk2
