Author Topic: Its too cold!  (Read 2469 times)
Offline Si
Its too cold!
« on: 12 January 2006, 12:20 »
Ok, just a quick question...
My car takes about 15 - 20 mins of idle to get the temp gauge to read halfway when leaving car without driving it.
Is this about right?
also, when its at halfway and i start to drive it the temp drops to the white part in a short time!!?! i know its cold weather but this cant be right? (wont get hotter than this while driving.)
Also the heater inside gets warm, not hot!  :angry:
Could it be i need to flush the coolant? it cant be Thermostat because at 1/2 way the fan operates so it must be working?  :undecided:
I LOVE THE SOUND OF CARBS IN THE MORNING
Judderi
Re: Its too cold!
« Reply #1 on: 12 January 2006, 12:22 »
What motor is yours si?
Offline Si
Re: Its too cold!
« Reply #2 on: 12 January 2006, 12:59 »
1.6 Driver.
Judderi
Re: Its too cold!
« Reply #3 on: 12 January 2006, 13:02 »
I wont be of much use then! 1st thing would be to flush the system. Stick a hoze pipe down every oraface you can get to! Time for your colonic my driver!  :evil:
Offline Si
Re: Its too cold!
« Reply #4 on: 12 January 2006, 13:04 »
 :laugh:
Will brave the cold weather outside in a bit and give it a go! Finish my cup of coffee first though me thinks!  :smiley:
Offline Organisys
  • Old and Slow...
Re: Its too cold!
« Reply #5 on: 12 January 2006, 13:18 »
Heater.....do a search on 'heater' on here, for some tips on ridding airlocks....It will then work warmer,
 :smiley:
Offline Si
Re: Its too cold!
« Reply #6 on: 12 January 2006, 13:23 »
Didnt think of doing that.  :embarassed: Cheers bud.
Offline Mr Blue
Re: Its too cold!
« Reply #7 on: 12 January 2006, 13:31 »
sounds liek the cooling system is working which is good but the reading to drop that low is abit dodgy.
coolant flush and 50/50 mix with anti freeze then get back to us i think :wink:
Re: Its too cold!
« Reply #8 on: 12 January 2006, 14:42 »
1. You shouldn't warm the engine up by sitting there idling, you should drive off straight away ;)
2. It sounds like the thermostat is missing or stuck open to me :)
Offline Si
Re: Its too cold!
« Reply #9 on: 12 January 2006, 14:44 »
Maybe, would that effect the Auto Choke? cause its operated by water temp isnt it? Would explain the missfires, spluttering, and stalling at junctions?!  :undecided:
