Author Topic: Its too cold!  (Read 2470 times)
Re: Its too cold!
« Reply #10 on: 12 January 2006, 15:03 »
Possibly, but its more likly to the the coolant channel o'ring in the inlet manifold, see my 2e2 FAQ in the garage section ;)
Offline roverspeed
Re: Its too cold!
« Reply #11 on: 12 January 2006, 16:04 »
Wahey, my crappy 1.6 also does this Si
Everything is exactly how you say it is, except my temp guage stays just below halfway, but takes ages to heat up, and every so often my crappy peirberg thinks it needs the choke open, and i get splutterin etc, and stalling when off the throttle in neutral, will have to try a coolent flush and change that o ring!!!
Warren
Re: Its too cold!
« Reply #12 on: 12 January 2006, 16:34 »
check the thermostat too, run the engine from cold and check the bottom rad hose, it should stay stone cold till the gauge gets to about half way.  If not the stat is stuck open.  Of course it could be the gauge sender is reading too cold too :)
Offline mjamoose
  • I'm off a hunting! (for a head gasket)
Re: Its too cold!
« Reply #13 on: 12 January 2006, 22:31 »
I had the same problem on my 1.6 carb, auto choke wouldn't switch off until 3+miles into journey.
The car would take ages to warm up and the heating wouldn't work properly.
Turned out the thermostat was stuck open and needed to be replaced.  After that no problems!
WARNING DRUMMER ON THE LOOSE :evil:
