Author Topic: question :)  (Read 2454 times)
Offline pinkcrush
question :)
« on: 05 January 2006, 22:41 »
forget my other posts, but
why would a car, go from running ok, to pulling over, stopping, but not turning the engine off, to pulling away with no power ?
it was fine, but then nothing, foot on the floor but only doing 10mph and struggling to do that, it didn't cut out but was close to it.
but i stopped, left car for about 30Min's and it was back to high revs but with power
any thoughs, cos iam getting close to taking her off the road :(
Offline [han]
  • Graphic Designer for Haribo
Re: question :)
« Reply #1 on: 05 January 2006, 22:44 »
its a driver ain't it? (from pics) mine was the same.. make sure its not firing on two when starting, cos mine was,
have to rev mine until it revs clear as its lumpy at first, and i get that no power thing, even tho foot is to floor,
my lil bro sorted my carb, and just make sure you give it time to warm up, and give it some good revs until it stops been lumpy... (if that makes sense!)
i'll mail ya if needs be! xx
Offline Agreeable Slick
  • Unit
Re: question :)
« Reply #2 on: 05 January 2006, 22:45 »
As i have mentioned the not cutting out sounds like the auto choke not doing its job, the no power and then power is a bit iffy. Can't say i have ever had the problem. Might possibly have something to do with the accelleration cable being stretched or possibly breaking in the casing...  :undecided: :undecided:
Offline pinkcrush
Re: question :)
« Reply #3 on: 05 January 2006, 22:48 »
thanks han
but yeah it is a driver, but ive sorta had that one, well still do, but it was warm when it did it this time, thats why i might take it off the road, soooooooo many problems :(
but thanks again
ann
slick..the cable was checked :( but no hint of any probs
as for the auto choke this all goes back to the poxy carb being changed  :cry:
« Last Edit: 05 January 2006, 23:44 by pinkcrush »
Offline [han]
Re: question :)
« Reply #4 on: 05 January 2006, 22:50 »
a new acc cable did help me, but mine was waaaaayyyy fooooked!  :nerd:
Offline bulk66
  • Im broke an it aint a joke!!!!
Re: question :)
« Reply #5 on: 05 January 2006, 22:58 »
Have you try-ed replacing your ignition leads mate i had a 1.3 that would lose power for no reason and it turned out to be the leads being fooooked and if your still running a piersburg carb burn the thing Ive had old bms and golfs with piersburgs and they are nothing but trouble get a weber put on and you can have a manual choke that comes in the kit loads less trouble...... :wink:
« Last Edit: 05 January 2006, 23:00 by bulk66 »
Offline pinkcrush
Re: question :)
« Reply #6 on: 05 January 2006, 23:02 »
leads have been changed :(
but yeah your not the 1st to say get a weber :)
might help  :huh:
but thanks
Offline bulk66
Re: question :)
« Reply #7 on: 05 January 2006, 23:57 »
I was just looking on ebay and theres a carb and filter on there for a 1.6 or 1.8 on the search type in golf mk 2 and its about half way down the first page its £120 quid at the moment.... :grin:
Offline Haribo!
Re: question :)
« Reply #8 on: 06 January 2006, 02:31 »
you can have my weber for a fair price if you want, its not running properly as its dirty inside and needs a proper taking apart and cleaning out, i aint doing it cause im not at all good at that sort of thing, it should be absalutely fine once thats done, i cant see any reason why not anyway, they seem simple enuf devices???
Offline pinkcrush
Re: question :)
« Reply #9 on: 06 January 2006, 10:26 »
ive looked on ebay, but all the  weber's ive looked at state for a manual does it matter ?
many thanks
ann
