Author Topic: vag com  (Read 4006 times)
kingturbo
vag com
« on: 30 December 2005, 01:41 »
anyone know where if the leads work that are for sale on ebay and if so where can i get the software to use it and is it easy to use I'm asking as my airbag light has come on and the local specialist wants £25 to turn it off then more to fix the problem. I'm thinking it might just be worth me buying the software to sort it out myself as i intend on keeping the car for a while and i will probably use it again what are your thoughts have any of you got or used this or should i just leave it well alone cheers.
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: vag com
« Reply #1 on: 30 December 2005, 20:00 »
dunno about the ebay ones, here is the link to the suppliers of vag com tho :cool:http://www.ross-tech.com/products.html
kingturbo
Re: vag com
« Reply #2 on: 07 January 2006, 01:29 »
so if i get this program and one of the leads off ebay will this work and has anyone done it if so is it easy to use
Offline Phil_M
Re: vag com
« Reply #3 on: 07 January 2006, 17:45 »
Yes i got a lead of ebay and it works fine. you are a bit limited to what you can do with the free software from ross tech, but is ideal for finding fault codes.
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
Offline charri42
Re: vag com
« Reply #4 on: 07 January 2006, 17:53 »
Rich, have you tried powering down (disconnect battery) and seeing if this works? This was first recomendation by Audi main dealer when we had a similar problem with airbag light. In our case it didn't work, and we ended up £400 lighter having had a new side airbag fitted.
BTW, not sure if you know, but it is my understanding that the Golf defaults to NO pyrotechnic safety devices when light is on (no airbags or seatbelt pre tensioners) - good because you need not worry about inadvertent bag deployment (scary) Bad because they could save your life.
Good luck!
kingturbo
Re: vag com
« Reply #5 on: 07 January 2006, 20:25 »
ok thanks ill try disconecting my battery first see if that works but ill probably buy a lead off ebay anyway because just recenly ive been getting a coolant warning check service manual come up on the dash it doesnt always do it just sometimes ill see if i can sort that as well thanks guys
Offline Mr Blue
Re: vag com
« Reply #6 on: 08 January 2006, 00:18 »
i got a lead off egay. works :nerd:
Offline adyh
Re: vag com
« Reply #7 on: 11 January 2006, 17:35 »
Mine is from E-bay and works fine . And you can allways find OBD-II software on the internet if you know the places to look .
Offline richandhazel
Re: vag com
« Reply #8 on: 17 January 2006, 00:02 »
I'm just picking up the latest VAG COM software and lead. Apparently, according to my mate at work who is supplying me, as soon as you plug it into your car it unlocks the software to a full running version. Will let you know how I get on.
Just ordered the cruise control from VAG and need the VAG COM to switch it on in the ECU :undecided:
kingturbo
Re: vag com
« Reply #9 on: 17 January 2006, 15:51 »
ok thanks where are you getting the software and lead from
