Author Topic: vag com  (Read 4005 times)
Offline richandhazel
Re: vag com
« Reply #10 on: 18 January 2006, 19:04 »
A mate from work is getting it all for me. Should have it by Friday.
Re: vag com
« Reply #11 on: 24 January 2006, 07:18 »
Now got it and it works fine. Fitted my cruise control and I did indeed have to enable it with the VAG COM software.
Today I'll try running a ground scan and see what fault codes it throws up..........if any :undecided:
Re: vag com
« Reply #12 on: 24 January 2006, 07:21 »
Oh and by the way. You do have to be very careful when looking at the airbag side of things with the VAG COM. It throws up a warning about problems with  certain part numbers of airbags or something. I'll try and suss out more on that today. Only looked at it briefly as I was more interested in enabling the CC at the time.
Re: vag com
« Reply #13 on: 24 January 2006, 23:53 »
Hey, used it today and checked loads of parameters. One thing I picked up on.....fuel timing was too far retarded. Causes problems starting, both hot and cold and smoke. Have now advanced the fuel timing, now spot on. Aparrently should also improve the rev range, performance and economy.........
Hope to expect easier starting and less smoke on start up, at the very least.........will see........already averaging 50 mpg!!!!
kingturbo
Re: vag com
« Reply #14 on: 25 January 2006, 06:01 »
thanks it sounds like it does a lot i dont realy know anything about timing though so id leave that alone is the vag com you have got the same as the ross tech one will it all do the same thing if not is it copyable
Re: vag com
« Reply #15 on: 25 January 2006, 09:58 »
Yes its the Ross tech one. You can download it from their site as shareware. As soon as you plug it into your car and carry out a scan it registers the product.
Its then up to you if you want to activate all the available functions. I'm pretty sure the airbag scan is available under the shareware version......have a look at their online manual to confirm.
Mine is now fully enabled so can do just about everything.
« Last Edit: 25 January 2006, 11:46 by richandhazel »
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: vag com
« Reply #16 on: 25 January 2006, 11:04 »
So Rich - you got another car?
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Re: vag com
« Reply #17 on: 25 January 2006, 11:44 »
Yes mate. Mk4 GT TDI. You must have missed my post. I need to get some pictures up. Will take some now as its not looking too bad.........waxed it over the weekend.
Offline Madone_si
Re: vag com
« Reply #18 on: 25 January 2006, 11:47 »
that's what I'm after at the moment....
SOLD - BLACK SOY 92
