Author Topic: mk4 golf speakers  (Read 2348 times)
kingturbo
mk4 golf speakers
« on: 19 December 2005, 02:52 »
i have recently bought a mk4 gti when i picked it up i thought the stereo sounded a bit crap a few weeks later i looked into the problem. the muppet that owned the car before me had replaced the fronts with phoenix gold components and the rears with kenwood 3 way co ax speakers ive turned them off for now and am just using the fronts which sound ok but they are an old model and was thinking about buying 2 x sets of 6 1/2" components for the front and rear any recomendations i dont mind buying an amp to get the best sound out of them i have a gamma head unit and dont realy want to change this as i have a phat noise what do you guys have in your motors or do you think i would be best just trying to get hold of a set of original speakers?
« Last Edit: 19 December 2005, 02:56 by rich king »
Offline vr4000d
Re: mk4 golf speakers
« Reply #1 on: 19 December 2005, 16:08 »
are you running a sub??
if you are i wouldnt bother with the rear speakers you get a decent sound out of front comps and a sub, if you are just going to be running the 2 sets of comps then def amp them they will be a lot better.
what sort of budget do you have??
kingturbo
« Reply #2 on: 19 December 2005, 17:55 »
no i dont want a sub just quality front and rears the budget doesnt matter too much as im buyin it as i go not all at once
Offline vr4000d
« Reply #3 on: 20 December 2005, 11:16 »
well make sure you get the amp and speakers at the same time they dont like being run off the headunit then amped at a later date.
ive been running powerbass comps for the last 6 months and have found them very impressive they have great power handling and a good sound. i would recommend them if you want something a bit different.
check them out here
www.utopiaaudio.com
its the es6cv2
rrp £159.99
kingturbo
« Reply #4 on: 20 December 2005, 16:45 »
ok thanks ill check them out what amp are you using to power them
Offline vr4000d
« Reply #5 on: 21 December 2005, 12:02 »
at the moment im using a solid audio amp but there no longer available. will be changing to a crossfire vr202 soon http://www.crossfirecaraudio.com/prodInfo.asp?IDProduct=203
