Golf mk2
hydraulic tappies
Topic: hydraulic tappies (Read 2005 times)
theviper
GTI forum regular
hydraulic tappies
14 November 2005, 14:00 »
is ther a way of making them quite as it is sounding like a sawing manchine and i dont have the money to replace them yet and the noise doing my head in
Pete
Daz...
Re: hydraulic tappies
14 November 2005, 14:02 »
change the oil...
if that dont make em noticably quieter then they are fooked
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Judderi
Guest
The only cheap way of improving them is to flush your oil and put new in with a propper vw filter as they have a non return valve in to help keep the oil at the top end.
tobz.
14 November 2005, 14:03 »
Wynns hydraulic tappet cleaner usually does a good job at shutting them up.
Needs to be followed by an oil change a couple of hundred miles later though.
Quote from: gibby on 27 April 2007, 13:30
You got any pics of your dad's split ?
Si
15 November 2005, 08:26 »
What they all said...
I LOVE THE SOUND OF CARBS IN THE MORNING
Judderi
Guest
17 November 2005, 16:14 »
And if you change them do a write up with lots of pics so that i can copy.
Agreeable Slick
Global Moderator
Serious forum addict
Unit
Reply #6 on:
17 November 2005, 16:15 »
get a treatment called wynns hydralic valve lifter. Tends to do the trick worked in my old valver anyhow.
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
Daz...
Reply #7 on:
17 November 2005, 16:18 »
Wynns hydraulic valve lifter
^^^ is there a difference between these? or is it just a different name for the same thing??
Agreeable Slick
Global Moderator
Unit
Reply #8 on:
17 November 2005, 16:20 »
I used lifter in mine, but i would imagine they are pretty similar, as the lifter cleans and stops them sticking, and also lubes them so they do not rattle. Can't say i have ever seen a tin of cleaner.
I made this : ->
Daz...
Reply #9 on:
17 November 2005, 16:23 »
hmm..think ill go find myself some of that lifter stuff then, might quieten the old girl down a bit
Golf mk2
hydraulic tappies
