Author Topic: **Whats Wrog with my Dodgy Oil buzzer ?????**  (Read 2883 times)
Offline golf gti 16valve
« on: 11 November 2005, 00:13 »
Hi ppl i have a 88 mk2 gti 16v golf,and now and again the oil pressure buzzer will come on, the oil is fine and topped up,and its not the head gasket or anything like that,it seems to only happen after i drive it quite hard,it could just be a dodgy wire because when it comes on i just have to quickly turn sharpley and it will go off,but it only really comes on when i drive hard, any info would be great, cheers
« Last Edit: 11 November 2005, 09:43 by golf gti 16valve »
Offline silkyballs
  • more tea vicker??
Re: Dodgy Oil buzzer ?????
« Reply #1 on: 11 November 2005, 00:30 »
it could well be the strainer on the uplift is blocked slightly i think its a common fault not just on gti's but on more standard vw as it did it to me on my old jetta.i have to say the top half of the engine seezed up and stripped the cam belt totaly fooking it.when i swaped the engine i noticed there were a build up on the strainer also present there were bits of plastic that had broken off the dip stick carrier.be care ful it might not be that simple as a dodgy wire it could lead to an expencive rebuild!!good luck! jamie
http://[img]
« Reply #2 on: 11 November 2005, 00:44 »
OK GREAT,LOL I WONT BE SLEEPING WELL TONIGHT LOL, SO HOW MUCH OF A JOB is it to clean the strainer then?is it quite straightfoward then?i spose i beter do it just for my piece of mind,i need a new sump gasket anyways, how long should it take?? would i need to put new oil in etc?? let me know, thanks
« Last Edit: 11 November 2005, 00:46 by golf gti 16valve »
Offline Si
Re: **Whats Wrog with my Dodgy Oil buzzer ?????**
« Reply #3 on: 11 November 2005, 09:50 »
Disconnect the Buzzer?!!! If you cant hear it, it aint happening!!!  :laugh:  :laugh:  :grin:
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline Daz...
« Reply #4 on: 11 November 2005, 09:58 »
If you're putting a new sump gasket on then it should be an easy enough job..it's usually a film of oil covering the strainer stopping it from flowing properly...or it could just be a dodgy connection on the sensor  :undecided:
better safe than sorry tho  :wink:
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Offline silkyballs
  • more tea vicker??
« Reply #5 on: 11 November 2005, 10:02 »
thats a great idea???????not!!are you gonna pay for the rebuild if the strainer is blocked?dont listen to that dude it could turn out to be big trouble!besides that the when the buzzer comes on to tell you you are low on oil its too late the damage has already started which is why you should keep an eye on your levels all the time to insure the quality of your engine.even vw say that you shouldnt wait for the buzzer to tell you cos by that time your levels are way too low ,in the real world it should sound befor it actualy does.my advice is to put your blinkers on to all other advice that tells you to do sumik like dissconnect the buzzer!good luck, jamie
http://[img]
Offline Si
« Reply #6 on: 11 November 2005, 10:22 »
WOW! I was only joking!!!  :nerd:
Offline silkyballs
  • more tea vicker??
« Reply #7 on: 11 November 2005, 10:31 »
sorry dude maybe you should say ,some people would take what you said seriously and would have done what you said and in turn ended up with rebuilding ther engine.which is why people come on here for advice dude cos they dont know any better!as the old saying goes.....got all the gear but no idea!!! some peeps just dont have a clue!
http://[img]
Offline Si
« Reply #8 on: 11 November 2005, 10:33 »
K, i just thought the  :laugh:  :laugh:  :laugh:  :grin: might of given away that im joking?! Anyway....
Offline silkyballs
  • more tea vicker??
« Reply #9 on: 11 November 2005, 10:49 »
arrrrr fook it it dont matter any how hes got the jist of it i reckon! soory dude i wasnt having ago at ya.you know what its like some people are that thick thyey just go and do sh!te without thinking about it.my mate once asked me how to top up his oil and where to fill it upto.i told him the mark on the dipstick.then his so called mate says dont worry il do it for ya........the end result was oil coming out the rocker cover cos he had filled it to the top,,,,of the engine and then wanderd why it had shot all the seals and blew it all over the place!!!!!
http://[img]
