Author Topic: **Whats Wrog with my Dodgy Oil buzzer ?????**  (Read 2886 times)
Offline Si
Re: **Whats Wrog with my Dodgy Oil buzzer ?????**
« Reply #20 on: 13 November 2005, 12:06 »
My 91 has done 210k miles. The tappets are only just starting to tap if i cane it too hard. The valve stem seals are worn aswell cause it smokes a tad when i pull away or going down hill, simple job tho, just cant be arsed to get up and do it, i use the cheapest and thickest oil i can find at the moment, no point in putting good stuff in as its only the person behind me at the lights that gets it in the face!!  :laugh:
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline Mart8V
  • I really should know better by now.....
« Reply #21 on: 13 November 2005, 17:55 »
had the same problem once on my valve, cleaned oil strainer, in the end oil filter housing had some sort of problem!
  I have had the same problem for about 4 months. Have done all the changes (gaskets, sensor, oil pump, lubes etc) but still get the occasional buzz.  Have a feeling it may be the filter housing- is this an easy swap?
