Author Topic: Anyone else?  (Read 7843 times)
Offline HBW13
Anyone else?
« on: 22 April 2025, 11:58 »
Noticed a slight vibration/rattle when driving on uneven road surface. Think it's coming from passanger side door as when I put pressure on the door it stops.
Hard to pin point while driving but anyone else had anything like that?
Offline neiln20
Re: Anyone else?
« Reply #1 on: 22 April 2025, 12:48 »
Hi, i had this exact same issue and it drove me mad for months. In the end i located it to the panel which has the airbag lock key (you see it when you open the door). I prized this open and put some 10mm double sided tape on the few of the flat sections and a strip of single sided 10mm spong tape on the cover (between the cover and the door) and its stopped.
Try looking at that section....fingers crossed for you!
Mk.8 Gti Pure White, 18's Winter Pack.
Offline WebRoP
Re: Anyone else?
« Reply #2 on: 22 April 2025, 13:49 »
I have one on the drivers door, i have located it right in the corner where the small glass section is towards the back of the dashboard.. there's a bit of trim that is not fixed on and when you press on it, it stops the rattle, it flexes and vibrates.. i think i need to put something discrete in there to stop it moving.
MK 8.5 GTI - Urano Grey - 18'' Richmonds
Offline HBW13
Re: Anyone else?
« Reply #3 on: 22 April 2025, 15:31 »
 Just had a look at where you said, I don't think the noise is coming from there but I was shocked how flimsy the piece of plastic was there!
The sound I think is coming from around the door handle area on the inside, when I lean over I pause the upper part of door or the light bar and the vibration stops.
Got a few hours spare tomorrow am going to spend some time if I can see anything that would cause the issue, failing that back to VW I go.
Thanks for suggestions
:tongue:
Offline Carlosfandango
Re: Anyone else?
« Reply #4 on: 22 April 2025, 19:20 »
Probably the light strip in the door, I had this on my 8 and 8.5, if you push the tips of your fingers underneath onto the actual light bar itself the noise will probably stop, on my 8 I carefully pushed a small piece of loom tape up beside the light strip using a small screwdriver, whilst being careful to not add too much, that stopped it, on my 8.5 just pushing on the light strip did the trick.
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline HBW13
Re: Anyone else?
« Reply #5 on: 25 April 2025, 13:56 »
Located the noise!!!! It was driving me mad!!
It wasn't the light strip but the door padding above that
When I heard the nose then leaned over and put pressure on it, the noise would go. For the moment I've wedged a small piece of plastic in there and peace and quiet again.
Going back to VW in MAY!!!
Thanks all for the messages
One of the most annoying noises I have ever heard.
Offline MarkHowells
Re: Anyone else?
« Reply #6 on: 25 April 2025, 17:38 »
Stupid question but any chance of any photos showing these areas as I have an annoying rattle in the same area.
Thanks in advance.
Current: 2024 Golf GTI 8.5. Oyster Silver metallic black, black roof, Queenstown alloys, DCC, HK, spare wheel
Gone: 2018 Golf GTI 7.5 performance pack, Atlantic Blue, Santiago alloys, DCC.
Gone: 2014 Golf R, Lapiz Blue, Vienna leather, DCC.
Gone: 2011 Golf GTi, Reflex Silver.
Offline HBW13
Re: Anyone else?
« Reply #7 on: 25 April 2025, 22:58 »
Will do I'm the morning buddy.
Offline WLT
Re: Anyone else?
« Reply #8 on: 26 April 2025, 14:50 »
Hi, I think I have similar issue since November, didn’t manage to actually look into it, it is really annoying as it is gets louder on a cold days. But feels like sounds comes from the area right under the small window .
Current: Red 8.5 GTI
Past: Audi A4 45tfsi, Audi A4 35tdi, Golf 8 GTI, Golf 7…
Offline HBW13
Re: Anyone else?
« Reply #9 on: 26 April 2025, 18:56 »
Here's the pic. The wedge is the best I can do u til it goes back in.
The little hum/vibration was spool annoying
