Author Topic: Anyone else?  (Read 7855 times)
Offline MarkHowells
Re: Anyone else?
« Reply #10 on: 26 April 2025, 23:30 »
That's brilliant, many thanks for the pics. I will try to see where my rattle is coming from tomorrow.
Current: 2024 Golf GTI 8.5. Oyster Silver metallic black, black roof, Queenstown alloys, DCC, HK, spare wheel
Gone: 2018 Golf GTI 7.5 performance pack, Atlantic Blue, Santiago alloys, DCC.
Gone: 2014 Golf R, Lapiz Blue, Vienna leather, DCC.
Gone: 2011 Golf GTi, Reflex Silver.
Offline Carlosfandango
Re: Anyone else?
« Reply #11 on: 27 April 2025, 06:54 »
Hi, I think I have similar issue since November, didn’t manage to actually look into it, it is really annoying as it is gets louder on a cold days. But feels like sounds comes from the area right under the small window .
I have one on the drivers door, i have located it right in the corner where the small glass section is towards the back of the dashboard.. there's a bit of trim that is not fixed on and when you press on it, it stops the rattle, it flexes and vibrates.. i think i need to put something discrete in there to stop it moving.
In your case it is probably the panel at the end of the dash where the airbag key switch is, I had a small rattle from both the left and right panel on my mk8 and 8.5, I used some loom tape around the edges on the dash whilst the panel is removed, then when it clips back in place it sits nicely against that instead of the plastic. DO NOT UNPLUG THE AIR BAG SWITCH!!. If you do it will put up an air bag light when you reconnect.
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
