Author Topic: Coolant Silica Bag  (Read 47879 times)
Offline madstaff
Re: Coolant Silica Bag
« Reply #40 on: 14 November 2022, 20:08 »
Before you start messing around I highly recommend you clamp off the feed pipe that comes out the bottom of the rank, that way if the bag ruptures whilst your trying to pull it out it stops the contents of the bag entering the cooling system.
You can then remove the tank and flush it out.
I used a pair of forceps to remove the ones I did, but a long nose pair of pliers may work.
You'll have to do a bit of manoeuvring to get it out through the neck, but don't be shy as the bags are pretty tough.
Offline jaceyboy
« Reply #41 on: 14 November 2022, 20:19 »
I will do that thanks, did you remove the tank altogether to get it out?
MK7 GTi
Offline madstaff
« Reply #42 on: 14 November 2022, 20:27 »
No, just fished it out, clamped off the pipe just in case.
Although, it may be just as quick removing the tank if your not so sure how to get it out just to be on the safe side.
Syphon the coolant out, clamp both the pipes off, unplug the level sender, remove the tank, then pull the bag out.
Offline jaceyboy
« Reply #43 on: 14 November 2022, 20:31 »
Seems simple thanks :laugh:
MK7 GTi
Offline madstaff
« Reply #44 on: 14 November 2022, 20:36 »
It really is, once you've done it you'll realise you've spent more time talking about doing it than actually doing it. :smiley:
Offline jaceyboy
« Reply #45 on: 23 November 2022, 16:26 »
This is all very weird I checked, and I cannot see the bag, I checked my brothers TCR and can see the bag in his, his coolant tank is different to ours as ours has plastic around the inner bottle :undecided:
MK7 GTi
Offline madstaff
« Reply #46 on: 23 November 2022, 18:16 »
Yours may have the not so common twin-walled expansion tank where I think the bag is held between the inner and outer walls.
Pinched off Briskoda..
Removed a double walled mit silikat tank (part number ends in a ) and replaced it with a new M which is without along with mixing up fresh g13 to replace the old that was removed.
few interesting points...
That A suffix tank has a silicate container and a second mesh outside when I cut the old tank open.
The outer was intact, but the inner mesh was starting to degrade allowing a few crystals between the meshes, but still trapped safely.
The old tank has sensor prongs covered in plastic, the new just metal.
The tea bag style bags, it looks to me as if coolant movement could potentially catch the bag on these relatively fine prongs allowing them to damage the bag. Possibly the start of the problem.
either way, I think the older tanks are probably a safer design, but not infallible. The newer tea bag tanks seem like a bean counter design that’s backfired.
The basic M revision tank and replacing coolant at every water pump change is probably better for cars out of warranty. Changing coolant more frequently, eg every 2-3 years along with brake fluid would probably be good for additional piece of mind.
Offline jaceyboy
« Reply #47 on: 23 November 2022, 18:35 »
Ah sh@t yes, it is like twin wall, so it does have one in there then, does anyone know the replacement part number for a new expansion tank?
MK7 GTi
Offline madstaff
Offline mcmaddy
« Reply #49 on: 26 November 2022, 14:38 »
Do all the people removing the silica bag realise you need to change the coolant more frequently?
