Author Topic: Coolant Silica Bag  (Read 47882 times)
Offline madstaff
Re: Coolant Silica Bag
« Reply #30 on: 14 November 2022, 19:07 »
Ive looked into the expansion tank and cannot see the bag, yet I have Mit Silikat written on the bottle :huh:
Best way to see if you have one is to syphon the coolant out of the expansion tank like I explained earlier in the thread.
Offline jaceyboy
« Reply #31 on: 14 November 2022, 19:08 »
Yes I saw that, but it seems there is no space for a bag in there?
MK7 GTi
Offline madstaff
« Reply #32 on: 14 November 2022, 19:17 »
Where the 2 prongs for the level sensor end in the coolant you'll feel it there if its got one.
Best way is to syphon though, you'll see it then.
Offline jaceyboy
« Reply #33 on: 14 November 2022, 19:20 »
Cheers will check it out asap I think
MK7 GTi
Offline madstaff
« Reply #34 on: 14 November 2022, 19:23 »
My 2017 CS had one, so did my mates next door at work in his 2016 R.
Removed both of them, once I knew where it was it took about 2 mins to do the R.
Offline jaceyboy
« Reply #35 on: 14 November 2022, 19:51 »
Can you describe where in the tank it is please?
MK7 GTi
Offline madstaff
« Reply #36 on: 14 November 2022, 20:00 »
Standing at the front of the car it's around the 2 o'clock position and toward the outside of the tank.
You'll do well to feel it unless you've got long fingers.
Offline jaceyboy
« Reply #37 on: 14 November 2022, 20:02 »
Thanks, how do you pull it out?
MK7 GTi
Offline rowlers
  • I'm back - MK7 GTI
« Reply #38 on: 14 November 2022, 20:06 »
Just removed mine a couple of days ago. Dead easy, much easier than I was expecting. Long nose pliers and VERY gently wiggle it until you can get hold with fingers. The corners of the bag are quite stiff and take a little wiggling to get it out.
Offline jaceyboy
« Reply #39 on: 14 November 2022, 20:06 »
Thanks, going to try this in the morning
MK7 GTi
