Author Topic: Coolant Silica Bag  (Read 47837 times)
Offline Adam T7
Coolant Silica Bag
« on: 07 February 2022, 18:23 »
Hi All, 2 questions (1) will my MY2019 GYI PP have one fitted and (2) in reality, how frequent is failure of the bag?
Offline madstaff
Re: Coolant Silica Bag
« Reply #1 on: 07 February 2022, 19:02 »
https://www.vwroc.com/forums/topic/34794-coolant-tank-potential-issue/
Best way to see if yours has one is to siphon the coolant out of the expansion tank, it makes it easier to see/feel IMO, and you'll see it/feel it where i've marked.
Offline Adam T7
« Reply #2 on: 07 February 2022, 19:11 »
Thanks, I popped my finger early and I can feel a gauze so I’m assuming I have one. So, worth removing? - I assume all MK7’s have them, not just GTI’s so wonder what the failure rate is?
Offline LSBristol
« Reply #3 on: 07 February 2022, 19:28 »
Pretty sure the expansion tank has "MIT SILIKAT" printed on the side if it has it.
2017 mk7.5 non-PP, Indium Grey, manual
1991 T25 Camper
1967 Beetle 1500
Offline madstaff
« Reply #4 on: 07 February 2022, 19:32 »
I removed mine as small as the risk may be of the bag rupturing, it then blocks up the heater matrix.
VW did away with the silica bag, which "tops up" the antifreeze, in later model years anyway and changed the spec of the anti freeze to compensate.
All very good if it fails whilst in warranty, but out of warranty and your looking at a big bill, and i personally wouldn't want anyone removing the dash in my car.
I would rather top up the anti freeze every couple of years than potentially have to have the heater matrix replaced and all the associated problems that will inevitably come with having the dashboard out.
Offline madstaff
« Reply #5 on: 07 February 2022, 19:35 »
Yep, mine has MIT SILIKAT printed on the side and had the silica bag inside.
Offline skippy
« Reply #6 on: 07 February 2022, 20:48 »
I am pretty sure my car (MY2020) , does not have the silica bag, as Madstaff alluded to. I will double check though!
MK7.5 2020, Isaac Blue, standard spec
Gone but certainly not forgotten Candy White Scirocco 2.0 TSI
Offline SRGTD
« Reply #7 on: 07 February 2022, 21:03 »
My 2020MY Polo GTI+ doesn’t have the silica bag. I can remember someone over on the Polo forum posting a picture of the expansion tank on their car (a 2019MY GTI+) and that did have ‘Mit Silikat’ printed on the side of it.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Adam T7
« Reply #8 on: 07 February 2022, 21:29 »
Ditto
Offline sjl
« Reply #9 on: 07 February 2022, 22:25 »
Is it easily removed and is there a risk of tearing it open in the process?
