Author Topic: Rear Camera Emblem  (Read 2902 times)
Offline Yumraaj
Rear Camera Emblem
« on: 27 February 2020, 20:28 »
Hi I am thinking of adding a cheap camera to the rear VW emblem and was thinking if its possible at all.
What Im thinking is to drill the bottom part and attach a small camera to it then wire it to the MIB display and obviously I will have to code it for it to flip.
Does anyone think this will be doable?
Thanks
this is the camera
from AliExpress
https://www.aliexpress.com/item/33019599629.html?spm=a2g0o.productlist.0.0.700c659c9XW1bL&algo_pvid=3e361459-0a8c-4388-a87a-ba6e6dceeaed&algo_expid=3e361459-0a8c-4388-a87a-ba6e6dceeaed-0&btsid=0b0a0ae215828347494141236eee08&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Offline fredgroves
Re: Rear Camera Emblem
« Reply #1 on: 27 February 2020, 20:34 »
I'd say you have somewhere between no hope and Bob Hope.
Offline golfdave
« Reply #2 on: 27 February 2020, 20:34 »
It won't work...the MIB unit I am quite certain wil only work with the VAG camera....
& the VW emblem does not "flip"...the hidden camera pushes it out of the way...
Just buy the VW rear badge with the rear camera & fit that
many of these on AliExpress...ebay etc...
Offline Jim_mk7.5
« Reply #3 on: 28 February 2020, 08:56 »
Why buy a car like a Golf and then start fitting cheap crap to it?
NOW - 330e M Sport
Offline dean5125
« Reply #4 on: 28 February 2020, 10:22 »
I'm sure this has been discussed numerous times and someone had a quote for the genuine thing fitting by main stealer for £450-500 if its that bigger deal to you, I wouldn't want the pain of a DIY one personally! :undecided:
2019 (68) GTI PERFORMANCE DSG - new baby
2016 (66) GOLF R DSG - gone but definitely not forgotten
Offline Finglonga
« Reply #5 on: 28 February 2020, 10:31 »
That camera will be looking at the sky, it is designed to fit the same orientation the number plates lights fit. Coding it is as said going to be a game.
Offline Yumraaj
« Reply #6 on: 28 February 2020, 11:06 »
Thank you all. I will look into a proper reverse camera for it.
Offline rajb
« Reply #7 on: 28 February 2020, 11:46 »
As mentioned above you can get the genuine one retrofitted by the dealers for about £450 and then it’ll be all integrated properly and coded. Plus you’ll get the warranty with it too.
