This is a straight copy from the "GolfMK7" forum where I post these threads. You might have to create an account & log-in to see the pictures in full screen, due to their new website system.
This is the complete list of ALL the "How to retro-fit" guides that I have written for my Mk7 Golf Estate (GSW).
Full details in each guide if they need to be adapted for the standard 3dr or 5dr hatch.
The main reason for this is that some of the guides are getting buried way down the list & I have had a job locating them for people! So I thought it would be beneficial to create a sticky (hopefully) in one place which contains links to all of my "How to" guides.
Because my car was a "loaded" (I went mental on the options list) UK (European) GT (Highline) there are many common "How to retro-fit" guides that I did not write as those items came factory fitted eg;- Euro light switch, LED reading lights, LED licence plate lights, LED visor vanity lights, Bi-Xenon's with LED DRL's, Front fog lights, Reversing camera, Dynaudio, etc., etc.
However this still left plenty of what I consider to be "essential" items not factory fitted!! Many of these items are factory fitted if you are in France or Germany, & yet my car came out of the same German factory as theirs!!
This proves that your country's importer are the ones who state the cars specification & many items they do not bother offering to buyers in the price lists etc... (not enough demand, marketing etc).
VW Golf Mk7 coolant tank cap modification:-
https://www.golfmk7.com/forums/showthread.php?t=49415VW Golf Mk7 screenwash tank cap modification:-
http://www.golfmk7.com/forums/showthread.php?t=26076How to properly OEM+ retro-fit more Dynaudio badges to a MK7 Golf
https://www.golfmk7.com/forums/showthread.php?t=42734How to retro fit the GTE air intake duct on the lock carrier
https://www.golfmk7.com/forums/showthread.php?p=624070#post624070How to retro-fit the 312mm front brake discs (288mm to 312mm swap) on a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=26006How to retro-fit the rear subframe harmonic damper from the Audi A3 saloon:-
https://www.golfmk7.com/forums/index.php?threads/how-to-retro-fit-the-rear-subframe-harmonic-damper-from-the-audi-a3-saloon.369369/How to retro-fit the Audi RS3 (2107->) Front Brake Air Guides/Ducts to a MK7 Golf;-
www.golfmk7.com/forums/showthread.php?t=41323How to retro-fit the Audi TT-RS Front Brake Air Guide/Flaps to a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=26005How to retro-fit the Audi Jack Pads to a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=26990How to retro-fit a bigger capacity battery to a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=7926How to retro-fit a fire extinguisher to a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=7939How to retro-fit the TPMS (SET!) Button to a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=26020How to retro-fit an ESC OFF / Traction Control Button to a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=7908How to retro-fit the door exit, red warning/white puddle, lights to a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=13887How to retro-fit skid trays, aerodynamic under trays, & stone guards to a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=8532How to modify & improve the gearshift for a MQ250 gearbox on a Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=14444How to change the oil on a MQ250, 5 speed or 6 speed, manual gearbox, Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?p=535289#post535289How to:- EA211 engine:- heat shielding & how to sort the design flaws in the coil pack wiring
https://www.golfmk7.com/forums/showthread.php?t=42100How to retro-fit the engine cover to a 1.4lt TSI, Mk7 Golf;-
http://www.golfmk7.com/forums/showthread.php?t=8285How to fix the turbo wastegate rattle on the VW Golf Mk7 1.4TSI 140PS;-
http://www.golfmk7.com/forums/showthread.php?t=28690How to replace the EVAP pipe, & silence some noise on all EA211, 1.2lt & 1.4lt petrol engines
https://www.golfmk7.com/forums/showthread.php?t=53576How to retro-fit the rear window, spoiler fins to a Mk7 Golf Estate/Variant/S.W.;-
http://www.golfmk7.com/forums/showthread.php?t=14217How to cover the hole in the rear bumper of a Mk7 Golf Estate/Variant/S.W.;-
http://www.golfmk7.com/forums/showthread.php?t=6471Misc guides:-How the VW Golf GTI Performance Pack (PP) “Front Differential Lock” (VAQ) works.;-
www.golfmk7.com/forums/showthread.php?t=39096Official Worldwide Maintenance Schedules for ALL versions of MK7 Golf, Hatch, Variant, & Sportsvan.;-
https://www.golfmk7.com/forums/showthread.php?t=41617
