Author Topic: finished boot.. over the top?  (Read 3757 times)
Offline baz_the_man62
« on: 13 October 2005, 11:34 »
1.sound deadened back half of car
2.made false floor with cut out for spare.. has a lift out cover with handle
3.made side mount amp rack.. mounted 3000w (1200rms) amp for the subs
4.floor mounted sony amp 300w (140rms) for sony 6x9s
5.floor mounted power cap
6.stealth shelf
7.quick release twin sub box with 2 kenny 12" subs
Offline Agreeable Slick
  • Unit
Re: finished boot.. over the top?
« Reply #1 on: 13 October 2005, 11:50 »
Looks alright.  :cool:
Power cap is a waste of time though.
Offline lowgolf
« Reply #2 on: 13 October 2005, 11:55 »
Very nice mate, maybe you coulld hide the 6x9 wires a bit better  :rolleyes:
<br /><br />Yeah!!!
Offline Mr Blue
« Reply #3 on: 13 October 2005, 13:03 »
you get more bass line when you point the subs towards the rear or the car :wink:
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 14 October 2005, 17:48 »
what kit is in there?
most 6x9's are only 50w RMS
Mk4 Golf 150PD
« Reply #5 on: 14 October 2005, 22:04 »
the 6x9's are rated at 60rms so the amp for them is a little more powerful but it can run without straining, just a simple 2 channel.
as for the position of the sub box, it had to lay down because of the false floor (too tall to fit under stealth shelf) and space dictated for it to go that way round.
Offline Mirage-
« Reply #6 on: 18 October 2005, 14:45 »
powercap's a waste of time?  Just curious as to why?
Judderi
« Reply #7 on: 08 November 2005, 15:40 »
I would recomend running your front speakers off the smaller amp and your 6x9's off y head unit if y really wanna keep em.
The remark about the power cap may be because bass amps demand extra power for longer periods of time. Where power caps can only supply a very short burst of power. You will be better of using an extra car battery in the boot than a power cap. But the real way forward is to use a batcap. Look them up!
Offline vr4000d
« Reply #8 on: 07 December 2005, 13:26 »
as said better bass if you have them firing towards the bootlid. and 6*9`s dont like working in the same air as subs because of the pressures.
and powercaps are jus max power bling there is no need to run one unless you like the look of it:) all they are is extra drain and connections on your power supply :smiley:
Offline GTI EDITION (aka LTD)
« Reply #9 on: 07 December 2005, 13:53 »
Just wondering wether any of you with boots full of ICE have ever had problems with your rear lamp bulbs blowing due to vibration / pressure from too much bass etc , As a bloke where I used to work was continually blowing his rear bulbs and that only seemed to happen when he turned up the volume ? :huh:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
