Author Topic: ACC deactivated?  (Read 50632 times)
Offline 2007GTI
ACC deactivated?
« on: 28 June 2018, 20:11 »
I have a message on my dash saying "ACC deactivated" I go into the menu and it is still ticked, the message won't go away.
I tried using my ODBEleven, but annoyingly it won't connect, will try again later.
Any ideas?
Offline itavaltalainen
Re: ACC deactivated?
« Reply #1 on: 28 June 2018, 20:28 »
Warning light on the dash?
Offline ajmoir36
« Reply #2 on: 28 June 2018, 20:32 »
Turn it back on by pressing the on button, on the steering wheel.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline 2007GTI
« Reply #3 on: 28 June 2018, 20:41 »
yes I turned it back on, message still there.
no warning light, just the warning message.
Offline Ulysses31
« Reply #4 on: 29 June 2018, 08:26 »
Check the sensor is clean? A tiny bit of road grime was enough to deactivate mine but a wipe with a snotty hanky soon sorted it.
White Golf GTI Mk7.5
Offline 2007GTI
« Reply #5 on: 29 June 2018, 13:24 »
it looked ok, but good idea ill give it a wipe
Offline 2007GTI
« Reply #6 on: 29 June 2018, 16:24 »
I cleaned the front sensor and it made no difference
« Last Edit: 08 July 2018, 12:21 by 2007GTI »
Offline 2007GTI
« Reply #7 on: 29 June 2018, 16:40 »
Just found this on another forum:
I had this twice so I decide to read the manual. If you press the "set" or "res" button it will show the message "acc deactivated".
You first have to turn on the ACC by pressing the little button that looks like a speedometer. There are two similar on the left hand side of the steering wheel and you need the top one. The bottom one alters between the speed limiter and the acc.
Offline Silvadadi
« Reply #8 on: 29 June 2018, 18:44 »
Any ideas?
I'm sure I got this message each time one of the cornering bulbs failed......take it both are ok?
Ordered Jun 18: R 5dr, IG, DSG, Prets, DLA, climate w/s and tints.
Aug 14 - Jul 18: GTD 5dr, CSG, DSG, S&S pack, Vienna leather and Santiago's.
Offline mb
« Reply #9 on: 29 June 2018, 19:15 »
I think it's just telling you that you haven't got ACC switched on which you can tell as you can see the mileage instead of a little speedo symbol. Mine is always on so it's a nice surprise to see the cars mileage when I switch the engine off!
