Author Topic: ACC deactivated?  (Read 50643 times)
Offline hog_hedge
Re: ACC deactivated?
« Reply #10 on: 29 June 2018, 19:56 »
I got air on the lanes and nearly bottomed my GTI out and got this message for a split second. I realise that this is no help whatsoever.
Offline Duke Dickson
« Reply #11 on: 30 June 2018, 02:10 »
I've had this & a little part of me thought I'd possibly broken it, given some of the responses here. However, came back to life once I'd pressed the requisite buttons.
Gut feel says it is possibly the same & if I can recall when less tired and nil alcohol inside, I'll let you know :). Or someone else will beat me to it handsomely.
« Last Edit: 30 June 2018, 02:23 by Duke Dickson »
Offline Finglonga
« Reply #12 on: 30 June 2018, 08:06 »
The ACC button and speed limiter OFF button also turns it on. It is the one directly right of the "RES" button. Press that and it will turn the ACC on or the limiter or the lot off. Have you tried pressing that to see it it's been turned off?
