Author Topic: Humming/Whirring type noise  (Read 7329 times)
Offline mcmaddy
« on: 09 February 2017, 18:18 »
Noticed a strange humming/whirring type noise this morning and also this evening coming home from work. Was out all day in car yesterday and never noticed a thing. Can't tell if it's cold tyre pressure related or even maybe a climate control fan. Does anyone know what the pp diff would sound like if it had no oil?? Outside temperature was 1 this morning and 1.5 coming home.
« Last Edit: 09 February 2017, 20:47 by mcmaddy »
Offline GTI_Ant
Re: Humming/Whirring type noise
« Reply #1 on: 09 February 2017, 21:25 »
Was the noise only there when moving and did the pitch vary with speed?  I had a small stone trapped between one of the brake callipers and the disc once and that made a row.
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
Offline mcmaddy
« Reply #2 on: 09 February 2017, 21:50 »
Hum seems to get noisier with speed. It's a bit like when you drive on fresh tarmac just after it's been laid.
Offline GTI_Ant
« Reply #3 on: 09 February 2017, 21:57 »
Dare I say check the tyre pressures and what does the tread look like? Are they wearing evenly?
Previous:
Offline mcmaddy
« Reply #4 on: 10 February 2017, 06:55 »
Pressures were checked earlier this week and both fronts look ok. Cars only got 1400 miles on it.
Offline monkeyhanger
« Reply #5 on: 10 February 2017, 08:11 »
Chris,
Have a look around the wheel arches, maybe one of the plastic liners are loose?
Offline mcmaddy
« Reply #6 on: 10 February 2017, 11:56 »
Going to have a quick check at lunchtime. Hope it's just tyre pressure and the cold weather and not the diff!
Offline lemski
  • 16v
« Reply #7 on: 10 February 2017, 19:22 »
Or a wheel bearing failed prematurely
Offline Tuckerjuk
« Reply #8 on: 10 February 2017, 19:54 »
Sounds wheel bearing related. If roads permit turn steering and see if noise goes away
Offline mcmaddy
« Reply #9 on: 10 February 2017, 21:29 »
Went out at lunchtime and turned wheels lock to lock to see if anything looked funny. Could see bugger all in the snow! Drove home tonight and wasn't exactly certain it was humming but did notice temperature was above freezing. Think I'll check tyre pressures tomorrow and maybe pop along to my local tyre place and see if they can spot anything untoward underneath.
