Author Topic: Humming/Whirring type noise  (Read 7336 times)
Offline RedHP
Re: Humming/Whirring type noise
« Reply #10 on: 11 February 2017, 00:07 »
Does it sound like its coming from below and as you accelerate...?
Red
Mk6 GiT since birth in 2010
YNWA
Offline mcmaddy
« Reply #11 on: 11 February 2017, 07:17 »
It just sounds like tyre hum but only seems noticeable at around 40mph.
Offline Snooze
« Reply #12 on: 11 February 2017, 07:53 »
Could be rear wheel alignment? I've got the same noise and told its rear wheel tracking.
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline monkeyhanger
« Reply #13 on: 11 February 2017, 09:23 »
Chris: You got the wrong car - paid for a GTI and ended up with a Hummer!  :whistle:
Best get it back in for warranty if it's not a wheel bearing, there's nothing rubbing in the wheel arches, and it is speed (not gear) dependent, it probably is wheel alignment. Check out the inside and outside rims of your tyres - just in case you have a sidewall bulge already.
Offline mcmaddy
« Reply #14 on: 11 February 2017, 10:17 »
Been to local tyre place first thing and has the car up on the ramp. Nothing untoward to be seen so checked the tyres and they are fine also. The tyres all look square with no bulges but they did say they've had two other gti's with Bridgestones on in the last fortnight with same complaint. I think the problem is more temperature related with the bridgestones but I'll wait to see what happens when the temperature rises (hopefully it will at some point this year  :whistle:) and if the problem gets worse I'll book it in to get wheel bearings checked.
« Reply #15 on: 11 February 2017, 11:18 »
Chris: Temp will have to rise a lot to see a big improvement in the Bridgestones. They're hard at the best of times, but they get a lot harder and grip drops off noticeably below 10C. For most non winter tyres that's 4C before performance drops off.
Offline mcmaddy
« Reply #16 on: 11 February 2017, 13:43 »
Yeah but I'm too skint at the minute to be able to change them out for Michelin 4s  :wink:
« Reply #17 on: 11 February 2017, 15:47 »
When you have the money, it'll be the best £400 you'll spend on the car. I don't regret spending the £600 on mine, I just bemoan the fact it was needed because I lost out on the VW tyre lottery twice on MK7s.  :grin:
If/when you are ready to buy, I can get you in at Costco Gateshead one weekend.
Offline mcmaddy
« Reply #18 on: 11 February 2017, 22:02 »
Yeah that'll be good Matt cheers. Maybe should have bought some winter wheels and then wouldn't have noticed haha. They do seem fine in normal temperatures or at least when warmed up.
Offline gtiaps
« Reply #19 on: 13 February 2017, 14:12 »
This is one of the reasons I put winter sport 5's on standard rims for the winter the ride and temp drops they seem spot on for the ride and handlings not too bad.
don't get me wrong the 19 inch santis with P zeros on were ok but aswell as the ride wanted to protect the rims from salt etc etc etc roll on the spring wen I put them back on  :whistle:
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
