Author Topic: Tilting n/s wing mirror  (Read 4281 times)
Offline vw spur
« on: 16 April 2016, 22:00 »
I've had my GTD a week now and so far so good, I'm really enjoying it.
Just one thing had been playing on my mind, the fact that the near side mirror didn't tilt downwards when reverse gear was selected, I had this on my last BMW and it's really handy as I can see the kerb as I reverse into my drive and don't want to catch the wheels on the kerb.
So I was sat in the car today waiting for the Mrs and I was just having a look through the settings and noticed that the car does have a tilting mirror and the box was ticked to say it was activated, I selected reverse and the mirror didn't move, I adjusted the mirror and selected reverse again and the mirror then tilted downwards, great that's exactly what I wanted but then when when I put the car back into park the mirror didn't raise back to its default position, this can't be normal surely??
The car is only a week old and really could do without having to drive it back to Swindon to be looked at if its a problem with it or is there something that I've not done correctly??
Collected 09/04/16 : Golf GTD Carbon Grey Sport & Sound Pack DSG Pro Nav Dynaudio Rear Camera High Beam Assist 90% Tints
Still pining for:2009 BMW 330i M Sport Convertible
Offline simonjj
Re: Tilting n/s wing mirror
« Reply #1 on: 16 April 2016, 22:24 »
Mirror switch on the door needs to be in the 'L' position for the tilt on reverse to work.
Mk7 GTD, 3 door, night blue, 19" Neuspeed RSE10
Offline Eccie
  • Keyless & Penniless
« Reply #2 on: 16 April 2016, 23:43 »
It'll move back to its normal position when you drive forward
« Last Edit: 16 April 2016, 23:46 by Eccie »
Offline vw spur
« Reply #3 on: 17 April 2016, 05:33 »
The switch is in position "L" now, the mirror tilts back but doesn't move back to its normal position after moving forward, I take it there's a problem with it, I'm expecting a call from the dealer in the next few days so I'll mention it when they call
Offline AntGTD
« Reply #4 on: 17 April 2016, 07:46 »
Can't remember where you are. do you have anybody in the area with VCDS who can do a scan?
2016 Mk7 Golf GTD 180(ish) Reflex Silver with loads of stuff
Offline vw spur
« Reply #5 on: 17 April 2016, 07:51 »
I'm in Basingstoke,  not too sure if there are any VagCom users around here
Offline AntGTD
« Reply #6 on: 17 April 2016, 07:53 »
I'm Winchester and work in Basingstoke :)
Offline wantmygti
« Reply #7 on: 17 April 2016, 09:35 »
Even above 10 to 15mph??
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline itavaltalainen
« Reply #8 on: 17 April 2016, 13:37 »
I was thinking the same..... it only tilts back up if you drive forward at a certain pace.
Offline Mark V GTD
« Reply #9 on: 18 April 2016, 11:03 »
Sounds like its fine to me - just drive off and it will revert back as long as you have set it up correctly.
