Author Topic: Tilting n/s wing mirror  (Read 4284 times)
Offline davewilliams000
Re: Tilting n/s wing mirror
« Reply #10 on: 18 April 2016, 12:55 »
I leave mine at the 'L' position all the time unless I need to use the heated function on the mirrors.
Also as others have said it should come back up when you above a certain speed. On mine the doors lock at the same time/speed.
2015 65 plate Mk7 GTD Manual in Tornado Red
   https://www.flickr.com/photos/davewilliams000
Offline KyleB
« Reply #11 on: 18 April 2016, 16:14 »
Yep, mine too!
Offline vw spur
« Reply #12 on: 18 April 2016, 19:31 »
Seems like I have the problem sorted, basically my seat was at its lowest position which then meant the mirror was adjusted to a position which was pretty much at its maximum tilt position , it barely moved when reverse was selected which led me to believe it was sticking in the tilt position.
So all I've done is raise my seat up a bit and readjusted the mirror and now the mirror visibly tilts and resets to its drive position as it should.
Thanks for all the help everyone
Collected 09/04/16 : Golf GTD Carbon Grey Sport & Sound Pack DSG Pro Nav Dynaudio Rear Camera High Beam Assist 90% Tints
Still pining for:2009 BMW 330i M Sport Convertible
Offline vw spur
« Reply #13 on: 19 April 2016, 08:01 »
I'm Winchester and work in Basingstoke :)
Have you got VagCom Ant??
