Author Topic: AGG engine revving issue  (Read 6548 times)
Offline Valere Oddoux
« on: 05 April 2016, 10:41 »
Hi all,
I have 2x golf cabrio with AGG engines, (97 MK3 and 98 MK3.5) the 97 is playing up!
When I start it, it revs up 3 or 4 times to 2000 plus rpm and then settles down to 1100 and stays there!
I have swapped just about everything from the 98 to the 97, ( throttle body, maf, air intake hose, air filter and body and sensor, heat sensor) the 98 still run fine with the 97 parts and the 97 still misbehaves.
I'm at a loss!
The crank angle sensor has been replaced before.
Please help
Val
Offline itavaltalainen
Re: AGG engine revving issue
« Reply #1 on: 05 April 2016, 11:31 »
ECUs swapped over?
« Reply #2 on: 06 April 2016, 23:17 »
Thanks,
Any tricks when doing that? Do they need to be reset to the car and how? Because I've swapped then and now I have two car that don't start......... :embarrassed:
Offline lemski
  • 16v
« Reply #3 on: 07 April 2016, 09:33 »
Havnt mk3 ecus got immobiliser fitted.
« Reply #4 on: 07 April 2016, 13:35 »
That's what it sounds like, it fires up and dies strait away like if using a key without the chip.
Is there a way to get around that?
Offline lemski
  • 16v
« Reply #5 on: 07 April 2016, 13:59 »
Try having the other cars key near the barrel so it picks up the chip.
I cant rember how they work but a mate use to have a key taped to a imob ring in his fusebox on his mk2
« Reply #6 on: 07 April 2016, 20:16 »
Other car keys won't help you there.
You can use the keys that fit car, you only need to match immo and engine ecu (no login required for that)
« Reply #7 on: 07 April 2016, 22:46 »
Swapped the ecu's to their proper car and they start again. Problem still there with the blue one.  :whistle:
« Reply #8 on: 08 April 2016, 10:53 »
Swap ECUs and marry it to cars immobiliser (no PIN required and you can marry it to other car again afterwards with no issues).
More here (despite what it says I never needed PIN):
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_I_ECU_Swapping
« Reply #9 on: 08 April 2016, 23:04 »
Thanks,
Interesting, but I don't have the program to do that.
