Author Topic: AGG engine cuts when warms up  (Read 3984 times)
Offline triplemaya
« on: 10 August 2015, 20:10 »
It is a Y reg golf avant garde so Mk 3.5
Cuts out once it gets fully warmed up and then go up a hill. Starts up fine as soon as it has cooled down a bit.
Standard AGG engine 2.0 injection.
Been in more than one garage.
Had new distributor, no help.
Supposedly had a new crank sensor just before I purchased 18 months ago.
Tearing hair out at this point.
« Last Edit: 10 August 2015, 20:29 by triplemaya »
Offline itavaltalainen
Re: GCC engine cuts when warms up
« Reply #1 on: 10 August 2015, 20:13 »
Let me guess, factory fitted alarm?
Offline triplemaya
« Reply #2 on: 10 August 2015, 20:27 »
Don't think so. Never noticed one. No blinking light on the dash. What should I look for?
Re: AGG engine cuts when warms up
« Reply #3 on: 10 August 2015, 20:29 »
red led next to door pin?
Offline triplemaya
« Reply #4 on: 10 August 2015, 22:24 »
Nope.
« Reply #5 on: 10 August 2015, 22:36 »
When you say cut out, does it loose power or cut out completely?
If it looses power completely....
How does relay 30 look?
Check soldering spots, if they look cold reflow solder.
Offline triplemaya
« Reply #6 on: 10 August 2015, 23:20 »
Thanks for helping.
It cuts dead. Sits dead til it has cooled off just a little. Then starts up a treat. Grr!
I will check the relay tomorrow.
and report back.
 Cheers.
Offline admc6
« Reply #7 on: 11 August 2015, 13:38 »
Does it stay running if you keep the revs up?
Offline GOLF-MK3-GTI
« Reply #8 on: 11 August 2015, 16:39 »
Its the Crank Sensor. Replace that straight away.
I've seen new crank sensors fail within a matter of days. Cheap GSF copy crank sensors tend to last 1 year and a half.
I've experienced this fault before. Replace its with a Genuine one
VW BUSH
« Reply #9 on: 11 August 2015, 18:53 »
Yep, I would scan it to be sure but patern sensors are pretty weak.
