Author Topic: changing discs and pads  (Read 4068 times)
Offline clancy
« on: 02 May 2015, 09:08 »
After a little advice, firstly is there a way to tell without going out and measuring if I have 280 or 288mm discs ? Wanted to order them today but can't get to the car today
Also,  was reading its wise/necessary  to replace the rear bearings at the same time ? What bearings are these as I will order them at the same time
And is there any abs related things that need doing at the same time ?
Thank
MK3 GTI 16v
Offline madmanmart
Re: changing discs and pads
« Reply #1 on: 02 May 2015, 10:21 »
I take it your have a GTI/VR6?
N reg cars are the cross over year for the brakes if before then 280mm if after then 288mm.
Yes if your doing the rears too then replace the bearing as their in the disc. The ABS ring is just pushed onto the back of the disc so just swap it over.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline clancy
« Reply #2 on: 02 May 2015, 10:25 »
Yeah I have an m reg 16v, so I'll order 280mm discs
And that's ideal, thank you
MK3 GTI 16v
Offline Foreveryoungaus16v
« Reply #3 on: 02 May 2015, 10:33 »
I would double check just incase the previous owner upgraded to 288mm.
163 BHP (TSR POWER RUN)
Offline clancy
« Reply #4 on: 02 May 2015, 11:00 »
Yeah that's a good point, best check
Was just hoping to order this weekend whilst euro car parts has its sale on
MK3 GTI 16v
Offline itavaltalainen
« Reply #5 on: 02 May 2015, 11:55 »
Ahem.... the wheel bearing are not in the discs on the 280 or 288mm discs, only on the back ones.
On the front I would not bother to change them unless they are noisy or have play.
Offline clancy
« Reply #6 on: 02 May 2015, 12:41 »
Yeah I know mate, I did say rear bearings, wasn't gonna do the fronts
MK3 GTI 16v
« Reply #7 on: 02 May 2015, 12:55 »
Didn't read that carefully, only got up a little while ago  :whistle:
There is only one set of wheels bearings for the rear (same for drums and discs). I have gone for Febi.
Ask our forum sponsor what deal he can do you.
Offline clancy
« Reply #8 on: 02 May 2015, 13:43 »
No worries bud, yeah I think I'll be ordering off him anyway as euros don't have everything I want in stock
MK3 GTI 16v
« Reply #9 on: 02 May 2015, 14:01 »
Yeah speak with Bb off here :cool:
