Golf mk3
hardmonkeys
changing discs and pads
Topic: changing discs and pads (Read 4069 times)
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
Re: changing discs and pads
Reply #10 on:
03 May 2015, 12:17 »
On the fronts the GTI changed from Lucas 280mm to ATE 288mm on chassis 1H-S-560001 (VR6 changed from Lucas 280mm to ATE 288mm 1H-S-400001).
Rears are all the same 226mm discs and as said you would need new bearings pressing in (I can arrange to do that for you if needed?)
And with the abs rings you can usually reuse the old rings, although I have known a few to split on removal but I also keep them in stock.
http://oemandmore.co.uk/brake-discs---pads---drums---shoes-86-c.asp
(let me know what you need as I'm sure I can sort a package deal for you)
clancy
Reply #11 on:
03 May 2015, 12:31 »
Cheers bb, I'm away till tomorrow but when I'm back I'll send you a message with everything I need
MK3 GTI 16v
gasketface
Reply #12 on:
04 May 2015, 00:50 »
If you have these front calipers you have 280mm discs on front :-
http://www.ebay.co.uk/itm/BRAKE-CALIPER-FRONT-LEFT-VW-GOLF-MK-3-III-2-0-GTI-2-8VR6-1991-96-/371158080898?pt=LH_DefaultDomain_3&fits=Model%3AGolf
|Plat_Gen%3AMK+III&hash=item566abedd82
If you have these :-
http://www.ebay.co.uk/itm/Mk3-golf-gti-16v-vr6-mk2-upgrade-g60-front-calipers-ate-vgc-288-283-/181729658639?pt=LH_DefaultDomain_3&hash=item2a4fee870f
You have 288mm.
Its the shape of the hole on top that tells them apart.280's have an oblong slot,288's have a diamond shape.
Golf mk3
hardmonkeys
