Author Topic: need help again please guys  (Read 5176 times)
Offline lee1989
« on: 13 April 2015, 10:21 »
Right long story short been haveing boost problems lately as my other thread states now ive got white smoke on start up but when its up too temp it smokes blue and really smells bad, doesnt smoke constant but if i stop for a couple of minutes and then pull off loads of blue smoke comes out im thinking turbo seals or could it be something else?? any help would be great thanks also its a 1.8t aum
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: need help again please guys
« Reply #1 on: 13 April 2015, 12:41 »
Sounds like a totally goosed turbo to me...
Offline lee1989
« Reply #2 on: 13 April 2015, 12:46 »
Cheers mate that is what i thought any idea how long roughly it will be drivable for until a new car is sourced?? and thanks for the reply
Offline Dalo Harkin
« Reply #3 on: 14 April 2015, 13:03 »
sounds like when my oil seals went in the turbo, if you remove one of the pipes after the turbo you'll probably get oil p*ssing out of it.
You can drive it like that but your only going to coat the exhaust in oil and block the cat, its about £200-£250 to get the turbo refurbished and it'll take you a full day/2 days of labour if you do it yourself and haven't done it before.
Offline lee1989
« Reply #4 on: 14 April 2015, 13:30 »
Thought so mate  :angry: stupid question but what pipe can i remove as im not clued up on turbo's as this being my first 1, also not worried about cat getting blocked up as i dont have 1  :grin: dont really want to spend that sort of money on it as it has 160,000 on the clock so will probs look for a less milage engine or another golf with less miles
Offline Mr_Orange
« Reply #5 on: 14 April 2015, 16:08 »
I'd suggest one of the intercooler hoses as they at lowest point. Remove the front bumper, to access the intercooler. Those hoses and pancake pipe will likely be full of oil. They run to IC behind osf wheel, I forget if you need wheel and arch liner out or not.
Build thread clicky
Offline lee1989
« Reply #6 on: 14 April 2015, 16:12 »
Ok thank u mate as soon as im off work ill take a look
Offline Mr_Orange
« Reply #7 on: 14 April 2015, 18:48 »
There would be normally a small amount in there after all those miles. If seals proper blown, you're looking for a flood when you pop hose.
Don't chuck in the towel so easy. I'm not familiar with your car or how much money and effort you've put into it, but weigh it up; Few hundred quid on a car you're familiar with or punt it and step into the unknown..... :/
Ours is a keeper at 155k miles, I'm waiting for the day when something goes pop.... When it happens I'm throwing a low mileage engine in. Maybe BAM if I can afford it :D
Build thread clicky
Offline lee1989
« Reply #8 on: 14 April 2015, 18:59 »
Personally ive only had it a year and everything its needed it has had mostly vw parts aswell, its serviced regularly (3 times since ive owned it) due to the miles i travel for work got loads of receipts for parts bought by other owners, so its been well looked after, but im just worried that the engine might go not long after.getting turbo done, ive also been looking at the bam engine and seen a complete 1 for £1,500 with full service history and low miles, but ive also been looking at the coupra R aswell  :undecided:, would prefer to do an engine swap but just have no where to do it  :sad:
Offline Mr_Orange
« Reply #9 on: 14 April 2015, 19:58 »
Is it cable or fly by wire throttle body? Plenty of low mileage, lower spec engines available out there. I'd settle for another lower mileage aum, or auq for the sake of a slightly younger engine.
BAM for me only if I can find a bargain, or tired example and decide its time I try a diy rebuild....
Is there no forum folk around your way could lend a hand with any work?
Build thread clicky
