Author Topic: Mk2 GTI starts then cuts out  (Read 7112 times)
Offline Gaved
« on: 17 February 2015, 12:13 »
Hey all,
As mentioned in my post in the newbie section, i have purchased a Mk2GTI that was non running but suspected it was the fuel pump and starter motor...which turned out to be right after i had the garage replace them because they were seized.  It was turning over yesterday and it started, but only run for about 2 seconds till it cuts out. The garage is now saying that it could be another fuelling issue, and this time its the fuse box inside the car (beneath the steering wheel) not delivering enough power to the fuel pump for it to run.
Question is, does this sound plausible? you can hear the relay clicking when turning the ignition. And also is it too much of a job to do, to switch fuse boxes? i'm more than happy to be doing that.
I welcome any response if you have had similar issues or know what may be wrong here.
**Also as this car has been stood for 7 years, could this be a result of fuel quality too?
Thanks
Gavin
« Last Edit: 17 February 2015, 13:27 by Gaved »
Offline sparkplug
Re: Mk2 GTI starts then cuts out
« Reply #1 on: 17 February 2015, 22:47 »
 what year is the car ? 8V or 16V ?
you replaced the fuel pump , the one in the tank ?
or the one under the car ?...
are the fuel lines full of crud ?
has the inline filter been renewed ?
« Last Edit: 17 February 2015, 22:50 by sparkplug »
1986 GTI atlas grey
Offline Gaved
« Reply #2 on: 18 February 2015, 01:40 »
Sorry, didnt mean to be that vague!
its a 1989 1.8 8v 3dr.
Yes they have replaced the one in the fuel tank from what i can gather, however i don't know if the one underneath the car is functioning properly or been tested.
Again i would have thought the garage would have checked the fuel lines and filter seeing as they knew the car had been stood for so long, but i will double check with them regarding those things you have brought up  :smiley:
To be honest, those are the things i would have checked myself but didn't have tools to hand. I will be annoyed if they turn out to be the cause! Presumed it would be an easy fix when i got it that it would have been up and running in no time...wish i just did it myself now  :cry:
Offline ians
« Reply #3 on: 18 February 2015, 09:30 »
There is a fuel pump under the car drivers side by the rear wheel. You should hear it prime its normally quiet easy to hear. Turn the ignition on without starting the car you should hear it. It has a large attached fuel filter on it. Put some new fuel in, but I had similar issues with mine and it was indeed the undercarriage fuel pump. Do it yourself it isn't hard get a replacement and bolt it...renew the fuel lines going to it too.
Offline Gaved
« Reply #4 on: 18 February 2015, 12:01 »
Thanks ians! I will go down and have a look now
Thank you very much for your help guys! much appreciated
Offline Gaved
« Reply #5 on: 18 February 2015, 12:40 »
ok so iv just spoken to the garage, they are adament that the fuse box under the steering wheel is the culprit...went as far to say if you can get the fuse box for me, i will have it running...scouring for a fuse box now then
** Am i right in thinking the 1989 is a CE1 fuse box?
« Last Edit: 18 February 2015, 13:24 by Gaved »
Offline sparkplug
« Reply #6 on: 18 February 2015, 17:04 »
 :smiley: good luck , no idea about the fuse box , take a picture of yours then compare online images may work
1986 GTI atlas grey
Offline ians
« Reply #7 on: 19 February 2015, 08:55 »
Where is your hazard warning triangle? On the steering column its ce2 in the dash its ce1. Good luck don't go getting ripped off man. These cars ain't that difficult to work on  :wink:
Offline Gaved
« Reply #8 on: 19 February 2015, 11:40 »
Thanks ians,
its on the Dash so its a CE1 fuse box im after. Only that, bit of welding and cambelt are the next things to do on this now, just want it back so i can play with it!
Offline ians
« Reply #9 on: 19 February 2015, 22:48 »
Thanks ians,
No problem, all gotta start somewhere  :wink:
