Author Topic: Oil pressure switch/ warning light light flashing  (Read 5265 times)
Offline thebassman
« on: 01 October 2014, 13:27 »
HI
I noticed a few days ago my oil light started flashing, on my GTI mk3 8 V, ADY engine code.
It seemed to be coming from the oil pressure switch high up on the engine block. It's the brown one.
I bought a replacement from GSF, fitted last night, topped up oil, still got the flashing light.
The switch I bought from GSF says it is 0.1-0.35 bar, the VW one I took off was marked 0.1-0.45 bar.
http://www.gsfcarparts.com/931vg0030
Could this be my problem, or should I be looking for something else.
It may just be a coincidence the switch was leaking and the light started flashing, I'm a bit lost as to where to start.
cheers
thebassman
Offline itavaltalainen
Re: Oil pressure switch/ warning light light flashing
« Reply #1 on: 01 October 2014, 19:28 »
your engine has two switches for oil pressure
when does the light come on? does it beep as well?
Offline thebassman
« Reply #2 on: 01 October 2014, 22:55 »
It comes on pretty much straight away and stays on. No buzzing or beeping though.
Thebassman
« Reply #3 on: 01 October 2014, 23:05 »
that's the low pressure switch then.... as you replaced it faulty wiring maybe?
VW BUSH
« Reply #4 on: 01 October 2014, 23:08 »
Are you losing oil?
Offline thebassman
« Reply #5 on: 02 October 2014, 07:06 »
It definitely was leaking oil from the switch, i have now replaced. I will keep an eye on it.
Thebassman
« Last Edit: 02 October 2014, 10:55 by thebassman »
Offline Jasikasisback
« Reply #6 on: 02 October 2014, 23:21 »
is your iriginal switch brown? if so the replacement gsf ones will not work...vw dealer will not have them either....scrapyard or specialty parts store only hope for a like to like
Offline thebassman
« Reply #7 on: 03 October 2014, 08:02 »
Hi
yes, the original leaking switch was a brown one.
Any idea why the new GSF or ECP switch will not work? Is it the wrong pressure rating or is the normally open/ closed function incorrect?
cheers
thebassman
« Reply #8 on: 03 October 2014, 12:53 »
You have two oil switches, one is for low pressure one for high.
Depending on which engine you have one of them is NC the other is NO. Do you have the part number of the one you put in now?
Offline thebassman
« Reply #9 on: 03 October 2014, 13:40 »
Hi
Yeah, it's the low pressure switch, high up on the engine block.
VW part number: 056919081C.
The vw one is stamped 0.1-0.45bar, the GSF switch is stamped: 0.1-0.35bar.
I went on the GSF website, entered my registration, and this was the one it recommended. I did also give them a call to verify before I ordered it.
cheers
thebassman
