Author Topic: Split hose - Advice....is this just a breathet  (Read 3290 times)
Offline TETSUOXGEZ
  • "If in doubt, flat out"
« on: 23 September 2014, 23:36 »
As in the title, is this just a breated and is it doing any damage? enginer wear and power loss?
Offline viperjsy
Re: Split hose - Advice....is this just a breathet
« Reply #1 on: 23 September 2014, 23:53 »
it will cause a air leek
Offline TETSUOXGEZ
« Reply #2 on: 24 September 2014, 00:02 »
So Boost leak  :sad:
Offline viperjsy
« Reply #3 on: 24 September 2014, 01:19 »
yeah
Offline rockmonkey69
« Reply #4 on: 24 September 2014, 08:08 »
Think there is some confusion here, that is a breather hose, it does not carry boost, instead it carried blow-by gases.
Offline TETSUOXGEZ
« Reply #5 on: 24 September 2014, 08:18 »
ii thought it was a breater... i'll get a better photo later
« Reply #6 on: 24 September 2014, 08:58 »
It is a breather, a leak here does not give you a boost leak, because it is a breather.
Offline TETSUOXGEZ
« Reply #7 on: 24 September 2014, 09:26 »
\No worries, i have a replacment on order anyway, but will it vause any running issues?
Offline WadGTI
  • Golf GTI'er
« Reply #8 on: 24 September 2014, 09:28 »
I was under the impression that you will lose mpg. Unmetered air getting in after the MAF?
« Reply #9 on: 24 September 2014, 10:23 »
It won't affect boost levels, but having said that, I imagine on a car without the TIP plugged, it will affect the running for the reason mentioned - unmetered air entering after the MAF, of course there is a hockey puck valve fitted to the TIP, but I'm not sure if it serves as a one way valve or not - most likely not.
« Last Edit: 25 September 2014, 17:13 by rockmonkey69 »
