Author Topic: Split hose - Advice....is this just a breathet  (Read 3289 times)
Offline davidgtrr34
Re: Split hose - Advice....is this just a breathet
« Reply #10 on: 24 September 2014, 17:11 »
This breather hose can cause power loss if it has a big hole but if it is a small hole then don't worry about it.
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline TETSUOXGEZ
  • "If in doubt, flat out"
« Reply #11 on: 24 September 2014, 20:30 »
Thanks for all the advice guys... the new Breather should be hear soon, so i will keep this updated with the results
Offline rockmonkey69
« Reply #12 on: 24 September 2014, 20:50 »
Or you could just blank off the port on the TIP current occupied by the hockey puck valve and vent to atmosphere or fit a catch can. VW probably charge extortionate amounts for what is a bit of rubber hose.
Offline TETSUOXGEZ
« Reply #13 on: 25 September 2014, 09:08 »
Cheers, sorry to sound like a complete n00b, but are ther any examples of this with piccys?
« Reply #14 on: 25 September 2014, 17:11 »
I removed all valves and have everything vented to atmosphere - using my rocker cover as a t-piece. The hose leading from the right side of my rocker cover leads ino the atmosphere under the car. My intake pipe doesn't have a port for the hockey puck valve, but on your one, you need only plug it with a hose bung and jubilee clip.
