Author Topic: 16V No spark / no fuel pump prime  (Read 2443 times)
Offline DubUpYork
« on: 31 July 2014, 11:17 »
Hi guys. Just stuck with this and after some advice.
I know there's a lot of threads about this however I'm stuck so thought i'd check this out with you before I tow it to the garage.
I am getting no spark from plugs or from the coil. However I can no longer hear the fuel pump priming when ignition is turned to no. 2. Could this cause no spark?
It is strange as two weeks ago I changed plugs (bosch) , leads(beru) , dizzy cap and rotor arm as they were a bit old. The car started first time after changing these. Drove it a few miles that day. Turned it off,  and drove another few miles back home.
However the next day went to start it and it would just turn over. I have since noticed I dont think I can hear fuel pump priming. I have checked all grounds,  battery terminals, dizzy leads, checked pump relay is in properly (not tried a replacement yet) and tried a different tci-h module but still just turning over.
Any ideas before I get it towed down the toad? I don't have a multimeter so can test much in that regard. The car does have 189k and the coil is looking original could it be that?
Many thanks!
Tom
Offline Sgt_Lemon
  • 8v owners club
Re: 16V No spark / no fuel pump prime
« Reply #1 on: 04 August 2014, 22:16 »
Have you checked to see if you have fuel through the injectors? All wires to the coil and earths?
Offline DubUpYork
« Reply #2 on: 12 August 2014, 09:02 »
Apologies for late reply ive been away with work last week. Im not too sure about the fuel from injectors I will have to test that but I would imagine not if the fuel pump doesnt prime?
I have replaced the coil for a new one, and checked all wiring to it and earths as best I can tell they seem okay.
VW BUSH
« Reply #3 on: 12 August 2014, 17:26 »
Ignition switch? Fuse box/relay burnt out?
Offline DubUpYork
« Reply #4 on: 15 August 2014, 18:13 »
I am leaning towards wiring. I have tried bridging the ignition switch however it still didnt start. I have also tried a (new) replacement relay and the pump still does not prime, but if i use the 18 relay the fuel pump does prime. Car will still not start however. Grrrrrrr
