Golf mk4
Wazzzer
no boost
Topic: no boost (Read 1485 times)
churchy 775
Just got here
no boost
02 June 2014, 18:24 »
golf 18t is not boosting ,when got it there was the o2 sensor so put one on made no different, put dump valve on and still the joy can someone help please
MoMartin
Here all the time
Re: no boost
02 June 2014, 18:51 »
Have a look for any vacuum hose that might have a kink in it, my car had boost problems, and it just turned out to be the vacuum hose coming off the n75 valve, causing it to stop the wastegate from working.
churchy 775
Just got here
Re: no boost
02 June 2014, 18:58 »
checked pipes , it did boost once for a couple of day and now nothing again, fitted boost gauge and it reads about 3psi
MoMartin
Here all the time
Re: no boost
02 June 2014, 19:44 »
Clogged pipe / knackered turbo then maybe?
Bandit127
Here all the time
Re: no boost
02 June 2014, 20:03 »
Scan it for codes. This should at least tell you where to start looking.
Standard (unmapped) boost is only about 5 psi or thereabouts, so you are not far off.
Dalo Harkin
Re: no boost
03 June 2014, 14:00 »
Itll be a block or cracked pipe somewhere, check under the inlet manifold maze of pipes under there
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
davidgtrr34
Here all the time
Re: no boost
Reply #6 on:
03 June 2014, 21:30 »
Are you getting no boost at all or are you getting very low boost. Check the bolts holding the turbo on the manifold
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Golf mk4
Wazzzer
no boost
