Author Topic: mpg  (Read 2371 times)
Offline daddy5x
  • any time now milltek cat back remap
mpg
« on: 22 May 2014, 18:13 »
 :cry:ive removed and cleaned my throttle body  replaced gasket and now it seems im getting less mpg    it says 18mpg  now   :sick:  any help/advise realy appreciated
standard gti turbo (aum     4 now
Offline dom
  • Back in a Mk4
Re: mpg
« Reply #1 on: 22 May 2014, 20:27 »
Did you realign the throttle body with vagcom?
Offline daddy5x
Re: mpg
« Reply #2 on: 22 May 2014, 20:29 »
no I didn't dom       I thought it would do its self after a few miles     !
Offline northeast_gti-t
  • "1.8T AGU"
Re: mpg
« Reply #3 on: 22 May 2014, 20:36 »
As dom has suggested re-align t/b with vag-com is best,although the ecu usually adapts with a few miles of driving too,i would scan for any fault codes also first up and go from there.
2000 Mkiv GTi 1.8T AGU
Offline daddy5x
Re: mpg
« Reply #4 on: 22 May 2014, 20:42 »
ive got my cable for vcds   coming over weekend  ill post back with any findings thx fellas
  • "1.8T AGU"
Re: mpg
« Reply #5 on: 22 May 2014, 20:48 »
good work :afro: Some good info here : http://www.ross-tech.com/vag-com/cars/vwmkIV.html
                                                      http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Offline dom
  • Back in a Mk4
Re: mpg
« Reply #6 on: 22 May 2014, 22:14 »
Based on your sig, you have an AUM which will definitely need it realigned by vagcom.
Offline daddy5x
Re: mpg
« Reply #7 on: 25 May 2014, 18:56 »
thx fellas ive now realighned with vagcom      :smiley:
Offline Bandit127
Re: mpg
« Reply #8 on: 25 May 2014, 19:14 »
While you have the vagcom kit out, check the water temp sender is giving reasonable values.
And go back over the throttle body work and make sure you haven't created an air leak.
Offline daddy5x
Re: mpg
« Reply #9 on: 25 May 2014, 21:55 »
how would I do that  this vag com is new to me   what would be reasonable values     thx
