Perhaps start by scanning for stored codes if you are new to Vagcom (actually VCDS).
If you want to dig about then the coolant temp can be found on this chart:
http://www.ross-tech.com/vag-com/m_blocks/001-009.htmlWith the engine fully warm you should see 85-95°C. Less than 80° suggests the temp sender and/or thermostat.
