Author Topic: golf auq cutting out  (Read 3975 times)
Offline jake-w07
« on: 21 May 2014, 18:11 »
hi guys my 1.8t has cut out on me 3 times in the last month without no warning or anything, all 3 times its been when i have been slowing down so i feel the power steering go look down and only the red battery light is showing. cracks back up no problem what so ever, also had abit of a rough idle intermitently and idling low. Code reader came back with a code for maf input low so i replaced that today as it was only a month old and under warranty.
any help would be great cheers jake
Silver Golf GTi 25th Anniversary 1.8T - Milltek Non Res Catback - 3" Downpipe & Decat - Forge 007p - ITG Cone Filter - Custom Remap
Offline davidgtrr34
Re: golf auq cutting out
« Reply #1 on: 21 May 2014, 19:03 »
It might be your fuel pump
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline brewey
« Reply #2 on: 22 May 2014, 11:37 »
It could be a multitude of things. Mine is currently running like crap too at idle. Have you looked for any leaks in the PVC hoses under the manifold?
Also it might be worth it if you haven't, try cleaning your throttle body?
Failing that what is you N75 like? Any perished/ broken wires?
2000 1.8T ARZ - OEM+
Offline jake-w07
« Reply #3 on: 22 May 2014, 11:43 »
Had a good a look as i can under inlet cant see anything though, not got vagcom so i cant do the throttle body cause i cant realign it :/ also n75 is that boost control valve ?
Fault code 16486 is back again today even with new maf on
Offline brewey
« Reply #4 on: 22 May 2014, 12:51 »
Yeah the n75 is the boost control valve up by the maf/ tip
The throttle body will realign itself after so many miles but obviously just be careful when cleaning ie. don't push the butterfly valve.
If you leave the tb connected and turn the ignition one click, leave something on the accelerator and it will open the butterfly valve to get both sides. Much easier/ better clean to actually take it off the mani though.
Offline jake-w07
« Reply #5 on: 22 May 2014, 13:03 »
All wires around n75 seem fine mate, will giv tb cleaning ago if the weather holds out tonight and see what difference that makes cheers
Offline Dalo Harkin
« Reply #6 on: 22 May 2014, 13:04 »
Have you rolled to a stop and then it just cut out like you've turned the engine off? this happened to me recently and it was the crankshaft sensor - its in the block to the right of the oil filter
Offline jake-w07
« Reply #7 on: 22 May 2014, 13:44 »
Car cut out while i was rolling would the crank sensor throw up a fault code ?
Offline dom
  • Back in a Mk4
« Reply #8 on: 22 May 2014, 14:39 »
The AUQ TB won't realign itself, it needs resetting with vagcom.
Offline jake-w07
« Reply #9 on: 22 May 2014, 14:52 »
I thought so, know anybody with vagcom in the north west that be willing to help me out for some cash ?
