Author Topic: golf auq cutting out  (Read 3984 times)
Offline brewey
Re: golf auq cutting out
« Reply #10 on: 22 May 2014, 14:54 »
Yeah the n75 is the boost control valve up by the maf/ tip
The throttle body will realign itself after so many miles but obviously just be careful when cleaning ie. don't push the butterfly valve.
If you leave the tb connected and turn the ignition one click, leave something on the accelerator and it will open the butterfly valve to get both sides. Much easier/ better clean to actually take it off the mani though.
The AUQ TB won't realign itself, it needs resetting with vagcom.
My bad, I thought that the DBW cars did realign.
2000 1.8T ARZ - OEM+
Offline jake-w07
« Reply #11 on: 22 May 2014, 16:04 »
Been told to try replacing camshaft sensor and crank angle sensor this a good idea ?
Silver Golf GTi 25th Anniversary 1.8T - Milltek Non Res Catback - 3" Downpipe & Decat - Forge 007p - ITG Cone Filter - Custom Remap
Offline jake-w07
« Reply #12 on: 30 May 2014, 09:02 »
Alright so been told loads of different things regarding my fault code 16486. Took it garage they couldnt find any leaks etc and with the problem being intermitent they reckon its down to maf(recently replaced for bosch new) or the wiring to the maf. Before i take it an auto electrician could anybody give me any advice or help ?
Gonna replace the thermostat tonight as my cars rarely been gettin to 90 could this be related ? Would like to do a throttle body clean but i dont have vagcom
Cheers jake
Offline WadGTI
  • Golf GTI'er
« Reply #13 on: 30 May 2014, 09:40 »
Cheers jake
Deffo get the thermo changed - will probaly solve your issue.
Offline jake-w07
« Reply #14 on: 30 May 2014, 12:54 »
Hope so will post how it goes
Offline Dalo Harkin
« Reply #15 on: 30 May 2014, 13:13 »
unplug the MAF and see if it feels any better, that'll be the best way to see if its shot
Offline jake-w07
« Reply #16 on: 30 May 2014, 14:32 »
Is deffo not the maf mate had two brand new mafs the last two weeks both bosch, only ever throws up that code though maf input low
Offline jake-w07
« Reply #17 on: 04 June 2014, 09:34 »
Cleaned out the throttle body yesterday and cured the problem, 50+ miles later and the cars been spot on im chuffed. Cheers the help and advice people
Offline Nino
« Reply #18 on: 04 June 2014, 10:27 »
MY 1.8t did this and i found it to be the DV.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline jake-w07
« Reply #19 on: 04 June 2014, 17:16 »
What the standard dv was failing or a forge 007 ? Running sweet again anyways but i clean the 007 out and relube it every few months anyway
