Author Topic: LED number plate lights  (Read 6418 times)
Offline Mattyj
« on: 28 February 2014, 21:51 »
Love them or hate them, does anyone have a set they would recommend? I got a set off ebay £14.99 didn't get the cheapest came with a ballast type resistor i think they don't fit to start and when i tried to connect the plugs the male spades pushed straight out the bk :-( they have an imitation vw plug on them which is a nice idea but the pins in it are straight and the vw ones are sort of staggered pretty poor tbh
Offline seanule
Re: LED number plate lights
« Reply #1 on: 01 March 2014, 00:22 »
I have r dash ones mate! would highly recommend them, give off a nice bright white light with a tinge of blue (which I'm into, not too boy racer-ish!) no error codes as yet, clocked up 12 months with them!
Offline Mattyj
« Reply #2 on: 01 March 2014, 09:46 »
Bit bright for me think the law states no white should be seen from the rear of the vehicle cheers tho :-)
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 01 March 2014, 10:47 »
You could buy the oem ones fitted to later cars and fit reaistors too them to stop the errors
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline dubber36
« Reply #4 on: 01 March 2014, 13:13 »
As my car now has rear LED's with the errors coded out, will OEM LED number plate lights just plug and play?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 01 March 2014, 14:49 »
Sadly not. Even turning the check off on vagcom for the numberplate lights still causes an error eventually. Only fitting the later control unit with the later software for the led numberplate lights fixes it. Or of cause fitting resistors to fool it. The sad thing is the oem one work on the mk5s without causing an error!...
« Last Edit: 01 March 2014, 14:53 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline Buck
  • Das Auto
« Reply #6 on: 02 March 2014, 12:44 »
I bought some LEDs before and the resistor burnt out on one of them. I was going to leave it with the bulbs in but it just looked poor with the yellow/orange colour so now I've got the OEM LEDs - bought from VW for around £40 then bought the resistors from car systems.pl for around £10
Nice LED light but not too bright. Suits the rear LED light clusters too.
Offline Obbzi
« Reply #7 on: 02 March 2014, 18:21 »
I just bought some LED lamp replacements rather that the whole unit, they came with resisitors so no errors and they look ace! I think I paid about £10 for them off ebay
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline Mattyj
« Reply #8 on: 02 March 2014, 18:32 »
Oh rite cool i thought they were a sealed unit??
Offline itavaltalainen
« Reply #9 on: 02 March 2014, 18:52 »
he didn't replace the number plate lights, just put a LED bulb into the standard bulb holder.
