Author Topic: LED number plate lights  (Read 6416 times)
Offline Mattyj
Re: LED number plate lights
« Reply #20 on: 02 April 2014, 14:43 »
No thought they did gutted :-(
Offline Mattyj
« Reply #21 on: 16 April 2014, 22:35 »
Bought some in line resistor harnesses but they aren't great need to adapt the loom so the lights stay sealed properly and ideas???
Offline JayGTD
« Reply #22 on: 18 April 2014, 12:32 »
Aye matty I have LED lights in my number plate. I've tried using vagcom to code them out but didn't really work. May get a set of those resistors too
Jay
Deep black pearl GTD | 18" Charleston wheels | Kenwood DNX520VBT | VWR Springs | GTI backbox and diffuser | Red grill stripes | Bi-xenon LED Projector's with 6000K HID's | Full interior LED conversion | LED Number plate lights | Heko wind deflectors | JDM Broadway Rearview mirror | GTD Seat inserts | Stage 1+ remap | Vagcom gauge sweep | Vagcom large digital speedo | Vagcom teardrop wipers | WIFI OB2 connector w/ Dashcommands |
Offline Mattyj
« Reply #23 on: 18 April 2014, 12:34 »
They are only like £4 but i don't want to cut into the vw loom want to get some gen plugs and adapt the harness to effectively plug an play
Offline david25
« Reply #24 on: 18 April 2014, 17:59 »
You could buy the oem ones fitted to later cars and fit reaistors too them to stop the errors
As my car now has rear LED's with the errors coded out, will OEM LED number plate lights just plug and play?
Sadly not. Even turning the check off on vagcom for the numberplate lights still causes an error eventually. Only fitting the later control unit with the later software for the led numberplate lights fixes it. Or of cause fitting resistors to fool it. The sad thing is the oem one work on the mk5s without causing an error!...
If you manage to patch the MK6 OEM lights, this is what they will look like (on a MK5)
http://www.mk5golfgti.co.uk/forum/index.php/topic,30092.0.html
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline Mattyj
« Reply #25 on: 18 April 2014, 18:29 »
Offline Mattyj
« Reply #26 on: 18 April 2014, 18:30 »
I was just going to put led bulbs in with an inline resistor mod harness
