Author Topic: Different sized spacers on same axle?  (Read 2326 times)
Offline Carl!
« on: 17 February 2014, 22:03 »
Ive ordered some 15mm spacers as my arch is catching on rear driver side. I was going to swap both as it made sense however reading about how the axle isnt set right, could I keep passenger side with 20mm and put 15mm on one or will that throw stuff out of line?!
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Different sized spacers on same axle?
« Reply #1 on: 17 February 2014, 22:31 »
I wouldnt. Would defo look funky...
Offline dom
  • Back in a Mk4
« Reply #2 on: 17 February 2014, 22:41 »
Why? The rear axle is off centre by 5mm so by using different width spacers the wheels will appear to 'poke' the same amount.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 17 February 2014, 23:19 »
Could you not centre the rear beam on the body mounting points?
Offline Carl!
« Reply #4 on: 18 February 2014, 07:35 »
I don't think it'd look funky as we are talking 5mm difference and as Dom said it'd even out the poke which is why im considering it if feesable. Thai-horse if heard people do it but assumed itd be a big job so never lookex into or considered it.
I'll probably just go 15mm a side whilst running these tyres,  just to be safe.
« Reply #5 on: 18 February 2014, 07:44 »
Surely 2.5mm is obtainable by simply undoing the mount bolts and levering the beam across a bit?
Offline AD1.8T
« Reply #6 on: 18 February 2014, 08:49 »
Its really easy to do mate loosen the bolts then tap the beam accross
« Reply #7 on: 18 February 2014, 10:44 »
I would look to centre the beam, would be the better option.
Offline Bellend
« Reply #8 on: 18 February 2014, 11:40 »
I would get a proper laser alignment place to move and set the rear beam.
Where all my moneys went.
Offline Carl!
« Reply #9 on: 18 February 2014, 20:02 »
it seems like a better option really long term, just assumed it'd be a major task. I'll have a look into it, cheers lads.
