Author Topic: Different sized spacers on same axle?  (Read 2327 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Different sized spacers on same axle?
« Reply #10 on: 18 February 2014, 21:53 »
I think you'd need a keen eye to notice the difference. An onlooker probably wouldn't think, ' That guy has definitely used a 5mm bigger spacer one side to even his beam.'.
I'd hate to think how much worse your OCD is compared to mine if you are noticing that on a regular basis!  :lipsrsealed:
Offline Carl!
« Reply #11 on: 18 February 2014, 22:27 »
im not noticing it, ive bought smaller spacers as one side is just catching the arch over bumps, the other side is fine. I'll swap them both and have a look, if it goes botherime I'll look at re-aligning the lot.
